Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Member Tommy V's Avatar
    Join Date
    Feb 2007
    Posts
    36
    New Berlin, WI
    BX24TLB
    Default Rear blade rotator
    I use the rear blade on my BX24 for clearing snow on my driveway and several neighbors. Sometimes I pull the snow and sometimes I drive in reverse pushing so I needed to be able to rotate the blade completely. I was tired of jumping on and off each time I wanted to change the position of the blade so I created a manual rotator. The shaft, bearings, and sprockets were from Surplus Center. The chain and wire were from the local hardware store. The rest of the metal was lying around the garage. Now when the cable is pulled while in the driver's seat, the locating pin is lifted up and the blade can rotate freely. To rotate the blade I simply turn the handle while the pin is up. When I get it to the correct position I release the cable and the pin falls back into the locating holes. So far it has work perfectly. The blade can rotate 180 degrees and in either direction. Since i know nothing actually happened with out photos, here they are.
    Rear blade rotator-001-jpgRear blade rotator-003-jpgRear blade rotator-005-jpgRear blade rotator-007-jpgRear blade rotator-004-jpg
  2. #2
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,370
    Lancaster County, PA
    Kubota L3200, Ford 1210
    Default Re: Rear blade rotator
    Very clever. I like that. I wish we were neighbors!
  3. #3
    Bronze Member hitts427's Avatar
    Join Date
    Jan 2012
    Posts
    60
    chesaning Mi.
    kioti lk 3054
    Wow great idea.
  4. #4
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    Massey Ferguson GC2400
    Cool......I like that
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  5. #5
    Gold Member
    Join Date
    Nov 2005
    Posts
    491
    Colebrook, N.H.
    Kubota L3830HST
    That's a great solution. Is it hard to crank?
    -Jim
  6. #6
    Join Date
    Feb 2007
    Posts
    36
    New Berlin, WI
    BX24TLB
    Quote Originally Posted by jimainiac View Post
    It turns very easily. I tried using the set up without the locator pin in place but the blade just rotated on its own.
  7. #7
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Very good idea.
    A small hyd motor would enhance your project even more, using a remote valve with motor spool to turn the chain.
    Surplus Center - 2.5 cu in WHITE 255040F3DD22AAAA HYDRAULIC MOTOR
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  8. #8
    Bronze Member WilcoKubota's Avatar
    Join Date
    Jan 2012
    Posts
    66
    The Netherlands, Sneek
    Kubota B1402
    Yeah, and with an hyd motor I would choose for a V-belt, so when you forget the lock pin you don't break the chain.
  9. #9
    Join Date
    Aug 2004
    Posts
    1,944
    Caldwell Co. NC
    2006 Kama554; 92 Belarus 250AS
    Nice work.
    I will add that if the pin isn't locked and the blade contacts the ground, the handle may swing pretty violently. Make it a point to stop fully before adjusting. A crank that is removed when not operating would add a little effort but a lot of safety.
    2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
  10. #10
    Silver Member FreshRouteFarm's Avatar
    Join Date
    Nov 2011
    Posts
    148
    Burtts Corner, New Brunswick Canada
    Case IH 485, David Brown 995
    That looks great. Very handy
    Case IH 485
    David Brown 995
    John Deere 430W
    Polaris Ranger 400
Similar Threads
  1. Replies: 24
    Last Post: 12-31-2012, 11:02 AM
  2. Rear Snow Blower - Hydraulic or Manual Rotator?
    By PandDLong in forum Snow Removal
    Last Post: 12-13-2012, 07:20 PM
  3. Replies: 0
    Last Post: 05-31-2012, 11:20 AM
  4. Front-End Loader Box Blade VS. rear angle blade VS. FEL for dirt driveway
    By Wyld Bill in forum Attachments
    Last Post: 12-14-2010, 12:48 PM
  5. Front-End Loader Driveway install - FEL, Box Blade or Rear Blade
    By fausdick in forum Attachments
    Last Post: 06-04-2010, 06:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
