Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Veteran Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    Default Re: Inverter on CUT?
    I think it would depend on what you're doing with it.
    If you occasionally have to punch a couple of holes with a drill, I don't see how you would have a problem. Perhaps get a little bigger Deep Cycle battery.
    If you're wanting to weld non-stop for hours at a time, it would be suboptimal.
    I put a 300A alternator on my Blazer. Not too expensive off of E-Bay. It had a tiny pulley to run about 2x the speed of a normal alternator, and it still sometimes doesn't kick in at idle. So, on your tractor, with a low speed Diesel engine, you would have to verify the high power alternators would be effective, especially if you wish to idle it while you are working.
    I had a 4000/8000W inverter that I was experimenting with earlier (not on a tractor). The biggest issue I had with it was that it would pull down the battery voltage under load, then hit an auto-shutoff. Cheap Chinese Stuff, the only way to keep it from hitting the auto-shutoff was to use a 14V battery.
    I assume you've seen the Raven threads.
    http://www.tractorbynet.com/forums/g...these-yet.html
    http://www.tractorbynet.com/forums/r...erator-go.html
  2. #12
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,721
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by FritzWH View Post
    In thinking of installing an inverter on my NH TC40DA so I can run shall power tools like a sawzall or power drill out in the field. Any advice or lessons from those who have done this and would do it differently next time?
    I didn't install it, just used it.
    Inverter on CUT?-pc281434-jpg
    Jumper cable clamps on the battery.
    Inverter on CUT?-pc281436-jpg
    Cut these limbs, with the TORO idling.
    Inverter on CUT?-pc281430-jpg Inverter on CUT?-pc281431-jpg
    Later upgraded to a 1500W and mounted it on a board that slid into the receiver hitch on the front of the tractor. Used the same type cable connector that the receiver mounted winch used.
    You can see the cable and the red connector between the headlight and the toolbox.
    Inverter on CUT?-pb190026-jpg
    Worked good for me, I didn't have any cordless tools at the time.
  3. #13
    Platinum Member High Compression's Avatar
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Kubota L5740-3/ Kubota ZD21 pro60
    I've gone through 5 inverters. Get a generator. I haven't gone through any of them yet.
    "It is better to be thought a fool, than to open your mouth and prove it."
  4. #14
    New Member
    Join Date
    Feb 2013
    Posts
    13
    WA, United States
    New Holland TC40DA, Cub Cadet GT2550
    Thanks for all the input. I don't really want to drag my 4000w generator into the bush, but that might be my best option.
  5. #15
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Many "modern" generators have a generator coupled with an inverter.
    Perhaps a little heavier duty inverter than the Chinese stuff.
    It never hurts to oversize your inverter somewhat, although the sub 1000W inverters are very cheap.
  6. #16
    Join Date
    Sep 2003
    Posts
    156
    Chehalis, WA
    Kubota L3200HST
    Just put out the money for a Honda EU200i, and don't look back. You'll then have a nice little generator you can take anywhere. Top that off with it's dependency and quiet running. You won't regret it.
  7. #17
    Elite Member
    Join Date
    Sep 2002
    Posts
    3,011
    Washington
    B7100
    I just bought the $89 Harbor Freight 900 watt generator for my field duty use. For the money, you can't beat it. No, it isn't a Honda, but it does what I need.
  8. #18
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,142
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Your initial conditions are idea for std modified sine inverter in the 1 to 1.5KW range. These will run up to circ saw and small chainsaw. Any tractor with an automotive sized battery would handle them for use on a non continuous basis.
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
Similar Threads
  1. Inverter Generators
    By BobRip in forum Rural Living
    Last Post: 09-26-2011, 08:06 PM
  2. Inverter
    By PioneerMan in forum John Deere Owning/Operating
    Last Post: 09-12-2011, 11:55 AM
  3. Inverter
    By Lloyd_E in forum Owning/Operating
    Last Post: 06-22-2009, 10:21 PM
  4. Power Inverter
    By dieselsmoke1 in forum Rural Living
    Last Post: 04-03-2006, 09:37 PM
  5. Inverter
    By daedong in forum Related Topics
    Last Post: 11-09-2004, 08:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
