Results 1 to 6 of 6
  1. #1
    Join Date
    Feb 2002
    Posts
    1,055
    WVa
    Kubota L3710, Ford 5600, Case MB4/94, Kubota B6200
    Default Relocate the battery.
    I've never been happy with the battery location in front of the radiator on the L3710. I'm looking at relocating it to a position on the right hand loader upright. There seems to be enough room to mount a battery holder behind the upright. Anyone relocate the battery on their tractor?
  2. #2
    Gold Member crazyangel's Avatar
    Join Date
    Feb 2012
    Posts
    329
    Western New York
    Kubota L5740-HST; Kubota RTV900
    Default Re: Relocate the battery.
    I have never had a problem with mine. So I never considered a move. I will admit that access is not super convenient though. Just out of curiosity, what trouble has it caused in the front?
  3. #3
    Join Date
    Feb 2002
    Posts
    1,055
    WVa
    With the loader attached you can't slide the filter out that screens the radiator. I'm constantly getting enough stuff on the filter that a bunch of it gets behind the battery. For some reason I've got some corrosion issues with the battery. I'd rather have the battery in a location where it doesn't interfere with airflow, make it difficult to clean the screen and create a corrosion issue.
  4. #4
    Join Date
    Feb 2012
    Posts
    329
    Western New York
    Default
    Quote Originally Posted by Darren View Post
    That all makes sense. Good luck with your project.
  5. #5
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,911
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    All the old iron tractors had the battery box or boxes on the sides of the tractors so they were easy to service. I think if you have room to do as you are proposing that it is a worthy project. With FELs on both my tractors I couldn't find anyplace to put even a small tool box that wouldn't interfere with operations so I guess the batteries will stay in front of the radiator on mine.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  6. #6
    New Member
    Join Date
    Nov 2010
    Posts
    2
    Kubota B 7500
    Hi Gary
    I relocated the battery on my B7500 due to airflow issues and debris as you mentioned. I mounted it on the LHS coming off behind the clutch pedal. I used part of the base of and old sack trolley as the base and some old metal arms from the junk bin as bracing from the free end back down to the FEL frame
    Graham
    DARWIN NT
    AUSTRALIA
    Relocate the battery.-photo0388-jpg
Similar Threads
  1. Relocate seat on Kubota B7800
    By rfkulka in forum Customization
    Last Post: 04-20-2013, 10:02 AM
  2. 790 exhaust relocate
    By jsb408 in forum John Deere Ag Tractors
    Last Post: 12-09-2011, 03:55 PM
  3. Relocate spring seat?
    By MillWeld in forum Trailers & Transportation
    Last Post: 05-18-2011, 05:43 AM
  4. Oil & Fuel L2800 fuel filter relocate
    By wfontjr in forum Kubota Owning/Operating
    Last Post: 05-14-2008, 09:04 AM
  5. looking to relocate pros/cons of upstate ny
    By farmerjim in forum Rural Living
    Last Post: 07-17-2006, 10:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
