Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    New Member
    Join Date
    Feb 2013
    Posts
    3
    Winsted, CT
    Massey 1529
    Default New grab hook bar added to bucket
    Hello everyone,
    This my first post here. I have read a lot of post and I have just got a new Massey 1529 and last weekend I add a grab hooks and a receiver hitch along with some rings inside the bucket. I have only been able to use the snow blower which works great. looking for some free time this spring and summer to get some seat time. I want to thank you all for a lot of great ideas. Please keep them coming. I hope I was able to attach the pictures correctly. If so i hope you enjoy the pictures. New grab hook bar added to bucket-102_0453-jpgNew grab hook bar added to bucket-102_0457-jpgNew grab hook bar added to bucket-102_0455-jpgNew grab hook bar added to bucket-102_0456-jpg
  2. #2
    Gold Member
    Join Date
    Apr 2013
    Posts
    312
    Linden, Ca.
    Husky GT2654
    Default Re: New grab hook bar added to bucket
    Looks like a nice job dude. You might think about using some grade 8 lock washers under those attaching nuts and a little never seize on the threads as well. Bruce
  3. #3
    New Member
    Join Date
    Feb 2013
    Posts
    3
    Winsted, CT
    Massey 1529
    Bruce
    Thanks, I did have lock washers on the center set of bolts but bolts were too short for both half inch plates. I need to get two longer bolts. Do have never seize on them i have just cleaned up the excess.
  4. #4
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,926
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Looks good, welcome to TBN.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  5. #5
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,776
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Quote Originally Posted by LindenBruce View Post
    As far as I am aware, there is no such thing as grade 8 lock washers. Bolts are graded by tensile strength, but lock washers are all the same regardless of the grade of bolt application. To me, nothing beats a double nut for locking a nut in place on a thru bolt. If it were me, I would put the nuts on the top side, so they can more easily be inspected for tightness rather than getting down on all fours to look under the bucket lip, but that is just my old age talking. For me, that is a major undertaking to get down and back up again.
    A simple but effective way to guarantee the nut wont come off, just take your welding machine and spot weld the nut to the bolt and forget buying new bolts and lock washers. If you should ever want to take the plate off which is unlikely, just cut the bolt with a cutoff disk on your 4.5" grinder.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  6. #6
    Gold Member deathtoblackberries's Avatar
    Join Date
    Mar 2013
    Posts
    312
    Battle Ground, WA
    Kubota BX2380
    A drop of blue locktite and forget it. Edit: on second thought, rust prone environment I second anti-seize and a jam nut or lock washer.
  7. #7
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Nice job.
    The PUPIL who does not surpass his Master, fails his Master.
  8. #8
    Join Date
    Jul 2011
    Posts
    84
    Massey-Ferguson 1529
    nice job! I plan on adding the reciever to my bucket as well, I have the same tractor probaly from the same Dealer!! goin on 2 years, its been a great tractor
  9. #9
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,790
    Branson, Mo.
    Kioti DK35se Hydrostat
    Another thing you can do with the nuts that dont have lockwashwers is to "stipple" the nut onto the bolt. Take an automatic centerpunch and use the it on the end of the bolt where it joins the nut to raise a burr between them. Do it 4 or 5 times around the circumference of the end of the bolt and the nut will stay put. It only takes a few seconds to do I have joined many things that way to prevent vibration from loosening nuts and bolts and it works well, and you can remove it it you have to with enough force to deform the burr.
    TEKTON 6580 Automatic Center Punch - Amazon.com
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  10. #10
    Join Date
    Jun 2008
    Posts
    10,776
    Bismarck Arkansas
    Quote Originally Posted by k0ua View Post
    James K0UA
    Or if you are a cheapy like me, just use a regular center punch and a small hammer. Works just as well and most folks have one in their tool box.
Similar Threads
  1. Strengthened bucket, added bucket chain hooks
    By hyperrust in forum Attachments
    Last Post: 03-22-2012, 01:00 AM
  2. Replies: 5
    Last Post: 03-03-2011, 04:45 PM
  3. First weld-on grab hook
    By jcliburn in forum Welding
    Last Post: 11-19-2010, 10:21 PM
  4. grab hook
    By Mosey in forum Attachments
    Last Post: 07-30-2002, 07:01 PM
  5. Bucket Grab Hooks
    By FarmerBob in forum Photos
    Last Post: 05-24-2001, 10:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
