Results 11 to 14 of 14
05-01-2013, 12:37 PM #11
- Join Date
- Mar 2013
- Posts
- 1,202
- Location
- Eugene, Oregon
- Tractor
- Toro D200, Ford 1715, International 884,
Re: Winch Question
I have an older Yale chain come-a-long. It isn't very long. It is heavy. But it has a lot of pulling power. One could probably put a 100 foot chain into it if one wanted though, if one had good high tensile chain.
But, I certainly like the winch on my Blazer. I have chained the Blazer to a tree before... Was that pulling the tractor out of a hole?
05-01-2013, 01:08 PM #12
- Join Date
- Mar 2013
- Posts
- 11
- Location
- Lafayette LA.
- Tractor
- Yanmar 1610 D
Re: Winch Question
Yes. See picture at beginning of thread
05-03-2013, 07:16 PM #13
- Join Date
- Nov 2008
- Posts
- 849
- Location
- Brampton, On\lot Powassan, ON Canada
- Tractor
- Kubota B4200\MF 135\Kubota B3200
Re: Winch Question
My project for this weekend is to build a 3PTH winch. It will be electric with spot for one or two batteries. Should weight in around 300 lbs. If the Op was using the box blade as a counter weight, a 3PTH winch would be a good option. If you got stuck using the box blade, then he needs another option.
If you are to carry a come-a-long, then you will need a large tool box for it and some chain. You should be able to install an ATV winch up front, IE 2500 lb with a pullyblock and tree saver strap, should get you our of most situations where you are by yourself miles from assistance.Unimogdave
05-05-2013, 10:14 AM #14
Like this?
Harbor freight 12k winch $300
The HF winch mounting plate was only $30
Deep cycle battery
The other Steel was on the scrap rack in the shop
http://www.tractorbynet.com/forums/a...hmentid=315101Kubota L4240 HST+ R-4's,
Similar Threads
Winch cable question
By easygo in forum Build-It YourselfReplies: 7Last Post: 04-21-2010, 11:56 AM -
Winches Winch question
By SFish in forum John Deere Owning/OperatingReplies: 3Last Post: 03-16-2006, 11:01 PM -
Another Winch Question??
By gpa311 in forum ATVs & Utility VehiclesReplies: 3Last Post: 06-12-2004, 10:36 PM -
Winch Question??
By gpa311 in forum ATVs & Utility VehiclesReplies: 0Last Post: 06-11-2004, 06:06 PM -
Question about ATV Winch
By Hoosier_Daddy in forum ATVs & Utility VehiclesReplies: 4Last Post: 02-22-2004, 07:39 PM
