Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Bronze Member davel8257's Avatar
    Join Date
    Jul 2012
    Posts
    99
    odon, IN
    kioti DS4510HST
    Default Grader Box mod -- Rod through the tube
    I have a 6ft Wallace brand Grader box which I've been using to grade a gravel parking lot. The crushed rock was very packed. I've had as many as 3 adults standing on the back adding weight with the knives fully extended downward the top link in the the shortest configuration possible.
    After several hours, I noticed that 2 of the pin holders welded to the top of the square tube had cracked. Another few minutes and the pin holding the knife would have been free removing any downward force on those knives.
    I touched up the holder with my wire welder. Those holders are not very heavy duty. I was thinking of a more heavy-duty solution -- such as welding some thick-wall tubing in their place. The 1/4" pins could be replaced with 5/8" pins as well.
    Then I got to thinking -- why not drill holes in both sides of the box, through the side plate and run a 5/8" rod through the inside of the square tube? The side walls of the tube would then carry the downward force onto the knives. I found a good picture on the wallace Mfgr website of the grader box -- I've annotated the hole and rod location on one side in the attached picture.
    Any thoughts?
    Attached Thumbnails Attached Thumbnails Grader Box mod -- Rod through the tube-grader_box_mod-jpg
  2. #2
    Gold Member
    Join Date
    Feb 2011
    Posts
    405
    princeton nc.
    JD 2320
    Default Re: Grader Box mod -- Rod through the tube
    i wouldn't, first off it is going to be difficult to get everything lined up to reinstall the pin inside the box. second there will be no support in the tube for the pin so it WILL bend. and finally if it DOES bend you are either gonna fight to get it out and/or back in.
    IMHO, I would just beef up the tabs on top and call it good.
    2010 JD 2320, 200cx, Frontier 1060R RFM, 2048 BB, LR1072 rake, IMatch, 5 suitcase weights.
    NEED MORE IMPLEMENTS!
  3. #3
    Veteran Member troutsqueezer's Avatar
    Join Date
    Sep 2010
    Posts
    1,308
    Pilot Hill, CA.
    Kubota B21
    Quote Originally Posted by davel8257 View Post
    Any thoughts?
    - Dennis
    Once you see the bandwagon, it's too late.
  4. #4
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,412
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    While this can be done and is how the roll over box blades are done, I believe that you will end up doing something else after you do this. With the roll over boxes, you put the rod in and you are done with it until you need to actually change a ripper shank out if it breaks or bends. With what you are proposing, if you use your rippers very often, I think that hassling with that rod again and again and again would get old REAL QUICK.
    Good luck
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  5. #5
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    This may be part of your problem. Box blades are typically designed around their own weight. Heavier blades are made of thicker steel, to take the greater forces generated by the heavier box/larger tractor. When you add ballast to a box blade, you are often asking for a damaged blade, which appears to be what happened here.
  6. #6
    Join Date
    Jul 2012
    Posts
    99
    odon, IN
    kioti DS4510HST
    re:Scrappy -- good point. I was thinking that I'd locate the hole as close to the top, inside (ID) of the tube, so that the thick wall of the square tube would bear downward force. Another factor I was going to consider is stepping up from a 3/8" pin to 5/8" pin. The holes holes in the knives are slightly larger than 5/8" (I tried a pin that I had and it moves in/out freely). But -- a long bent rod could be really hard to remove and even hard to re-insert when I want to raise the knives and just use the back blade.
    re: Joshua --> yes, I abused the box -- too much weight and traveling over hard-packed crushed stone driveway. Without the weight, the box just bounces around on top.
    I think I'll re-visit my local welding shop and see what thick-wall tubing (square or round?) they have that I can use to weld on the top and stay with the original design. I think I might step up to 5/8" pin size which will still allow for easy insertion and removal.
  7. #7
    Gold Member
    Join Date
    Feb 2011
    Posts
    405
    princeton nc.
    JD 2320
    Putting it in @ the top of the tube would work for the downward forces but just makes the upward forces even worse(I.E. when lifting the rippers out of the ground)
  8. #8
    Join Date
    Mar 2013
    Posts
    1,861
    Edmonton, Alberta
    MF 135
    Just put heavier mounts on the top. I'd bet that the shanks are heat treated and you'd never drill them. If you did might weaken them though as they'd have less meat between the edges and the larger hole. If the shanks are at the lowest setting, is there one of the adjusting holes sticking out the bottom of the tubing? If so, make a block for each side to go up against the tubing and just use a pin through the shank to hold it in place.
  9. #9
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,997
    Northern Vermont
    Kubota, Case, Deere
    On my grading scraper they have pieces of flat steel inside the cross tube. When the ripper teeth get force on them they push against the flat steel. The 5/8" pins never have any real force on them.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  10. #10
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,895
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by crazyal View Post
    His is different, the hole takes all the force.
    Grader Box mod -- Rod through the tube-box-blade-ripper-shank1-jpg
    This is your style, the notches can be on the front or back edge.
    Grader Box mod -- Rod through the tube-916f_1-jpg
Similar Threads
  1. M rod bolts
    By remchuk in forum Farmall Vintage Tractors
    Last Post: 04-30-2013, 04:58 PM
  2. BOX BLADE
    By MAN IN BLACK in forum Attachments
    Last Post: 04-23-2013, 11:32 PM
  3. Leaky stem on loaded tire.. to tube or not to tube?
    By CORamos in forum Kubota Owning/Operating
    Last Post: 08-03-2011, 09:47 AM
  4. Land Grader, Utility Grader, Road Grader?
    By ANiforos in forum Attachments
    Last Post: 03-17-2011, 12:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
