Switch, Work Light - T1270-33782 - $31.83 at Messicks
- from a Grand L60 and M7040
- on the kubota webpage showing the Grand L60 Features, it describes this switch as "Front Side Lights" and you can see it says FS and has the light shining down on the ground and not straight out. I am going to install "rock lights" on my tractor, which will be under the floorboard and light the area of the ground between my tires so I can look down at night and see if my tires are about to drop into a hole or off the edge of a ditch, etc. This switch will work great for that.
- is an exact match to the Hazard button on my tractor
