Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. #1
    Gold Member
    Join Date
    Oct 2010
    Posts
    313
    Sabetha, KS
    Kubota BX25D
    Default This Box Blade Had a Bad Day!
    I just bought a box blade off of good old Craigslist. It's a 5ft King Kutter (standard duty). The owner said he used it about 4 times. He was blading and caught a root. He admitted that he had it on too big of a tractor. As you can see it is a fixer-upper.
    The damage:
    1) Flat iron bent on back of 3PH
    2) One of the bottom points is bent and will need replaced
    3) The piece of iron holding the bottom connector is slightly bent.
    This Box Blade Had a Bad Day!-bb1-jpgThis Box Blade Had a Bad Day!-bb2-jpgThis Box Blade Had a Bad Day!-bb3-jpg
    I dropped it off at the welding shop this afternoon and told them what I wanted changed. I'm going to turn it into a pseudo-"professional" grade King Kutter box blade. The main upgrade is putting a box channel with gusset between the 3PH and the back of the box instead of flat iron that is bolted on. I also asked them to weld the 3PH at the two lower points. Someday I may gusset the corners of the box and other areas, but all I need to do is grade some rock.
    Here is the pictures from KK's website for what a professional series box blade looks like (the red box and arrow I added to show the welding shop):
    This Box Blade Had a Bad Day!-ab1-jpgThis Box Blade Had a Bad Day!-ab2-jpg
    Stay subscribed. I'll post pictures of the final result which I'm hoping is tomorrow or Monday.
  2. #2
    Join Date
    Mar 2013
    Posts
    1,844
    Edmonton, Alberta
    MF 135
    Default Re: This Box Blade Had a Bad Day!
    You could replace the bent flat bar that holds the top mount with angle iron. Had a Cultivator do the same thing and and fixed it with some 2"x3"x 1/4" angle iron. Doesn't look like a major repair. While it's there, you should get them to weld some 3/8" flat on the bottom of the side plates(inside) so it doesn't wear away so fast. That's what my Woods box blade has.
  3. #3
    New Member
    Join Date
    Mar 2012
    Posts
    7
    Parish NY
    Massey
    I bought the same POS and the second time I used it I caught a root and it literally ripped the center ripper out of the 4x4 box steel. Oops.
  4. #4
    Gold Member
    Join Date
    Oct 2010
    Posts
    313
    Sabetha, KS
    Kubota BX25D
    Quote Originally Posted by juiced10 View Post
    Orscheln Farm and Home sells a lot of them. That's where this one came from. When I'm looking to grade something other than driveways I may end up upgrading.
  5. #5
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Get them to make it a clevis style hookup. It will make it a lot stronger. Here is one I saw on craigslist a while back, listed as good condition.
  6. #6
    Gold Member
    Join Date
    Oct 2010
    Posts
    313
    Sabetha, KS
    Kubota BX25D
    Quote Originally Posted by 94BULLITT View Post
    Too late. I just picked it up. I agree on the clevis style hook up though. Also the idea of adding the extra steel at the bottom was great by ArcWeld above.
    The welds look great and everything looks like it was done well. I'll post some pictures tomorrow when I get it unloaded.
  7. #7
    Veteran Member Redbug's Avatar
    Join Date
    Aug 2004
    Posts
    1,975
    Columbia, SC
    Kubota L3830HST
    I have one of those box blades. If I would have known better back then, I would have spent more money and got a better one. Anyways...here's my fix to mine. I added extra plate under where the pin is. That piece of metal was bending so I had to give it more support.
    Attached Thumbnails Attached Thumbnails This Box Blade Had a Bad Day!-tsc-box-blade-6-29-a   This Box Blade Had a Bad Day!-tsc-box-blade-6-29-a
    Dave
    "If your sport does not put grease, blood, or dirt under your fingernails, then it's just a game!"
  8. #8
    Gold Member
    Join Date
    Oct 2010
    Posts
    313
    Sabetha, KS
    Kubota BX25D
    Here is the final product. I was a little nervous putting in the middle ripper. As you can see it barely clears. The rippers were in the back of my truck when this blade was getting rebuilt so its just an accident that the ripper fits. I thought they were going to put the tube in closer to the top. In the background of one of the pictures is the JD 2440 that is going to be pulling around for a while until I get my own rig. It worked pretty nice in my parents' driveway, but I'm going to wait until I get the two bottom pins get changed to the right size (cat 2) before I do too much more work with it.
    Enjoy!
    This Box Blade Had a Bad Day!-dscn0055-large-jpgThis Box Blade Had a Bad Day!-dscn0062-large-jpgThis Box Blade Had a Bad Day!-dscn0056-large-jpgThis Box Blade Had a Bad Day!-dscn0057-large-jpgThis Box Blade Had a Bad Day!-dscn0059-large-jpgThis Box Blade Had a Bad Day!-dscn0060-large-jpgThis Box Blade Had a Bad Day!-dscn0061-large-jpg
  9. #9
    Elite Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,855
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    Looks good!! All it needs is some yellow paint, and hook it up and go play in the rocks!
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, 5ft King Kutter II Rototiller, 5 1/2ft Cultipacker, 5ft Sitrex finish mower, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, Leinbach #11 Field Cultivator, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    It's not how slow you mow... it's how well you mow slow!!
  10. #10
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    The welding shop looks like they did a good job! Do be careful using that box blade on a Cat 2 tractor. It's just not designed to take the kind of forces that a Cat-2 tractor can put out, as the previous owner learned. By reinforcing some parts of a smaller box blade, you usually just move the failure point somewhere else, so don't count on your reinforcements to make the blade Cat-2-ready.
Similar Threads
  1. Hinged Box Blade vs. Fixed edge Box Blade
    By CTMassey in forum Attachments
    Last Post: 07-22-2013, 06:27 PM
  2. Bad gear box on mower deck?
    By Yellowvette in forum Parts/Repairs
    Last Post: 06-22-2013, 10:49 AM
  3. Box Scraper Can you ID this box blade?
    By sparc in forum Attachments
    Last Post: 05-17-2013, 10:34 PM
  4. Box blade
    By Rvrrat14 in forum Attachments
    Last Post: 05-08-2013, 05:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
