Results 1 to 10 of 14
07-16-2013, 10:54 PM #1
- Join Date
- Jul 2013
- Posts
- 12
- Location
- Alabaster, AL
- Tractor
- Kubota BX25D
07-16-2013, 11:04 PM #2
Re: made some new brush forks
Did you use 1in sq tubing tines?
07-16-2013, 11:29 PM #3
- Join Date
- Jul 2013
- Posts
- 12
- Location
- Alabaster, AL
- Tractor
- Kubota BX25D
1" x 2" rectangular tubing.
07-16-2013, 11:44 PM #4
Looks good!
Also,to the forum.
"If con is the opposite of pro, is Congress the opposite of progress?"
07-17-2013, 09:48 PM #5
- Join Date
- Jul 2013
- Posts
- 12
- Location
- Alabaster, AL
- Tractor
- Kubota BX25D
07-17-2013, 11:53 PM #6.................................................. .................................................. ..............................
07-22-2013, 10:22 PM #7
- Join Date
- Jul 2004
- Posts
- 1,986
- Location
- Bancroft, Ontario
- Tractor
- JD4300
I have a set that someone made using 1" cold rolled steel for tines. They are only about 20" long and not quite strong enough as I always seem to be finding rocks under the brush.......
07-24-2013, 01:40 PM #8
- Join Date
- Mar 2010
- Posts
- 253
- Location
- East Texas
The brush forks look good. I am making a set out of 1.5x3" rectangular tubing. I have it all cut but have not had time to weld it. It will hang from my bucket lip and be secured beneath the bucket. I have a set of heavy duty forks for heavy duty work but the brush keeps falling between the tines so the brush forks will solve that problem. Both sets will work with a grapple that I will build later.
Give us an update when you get to try it out.
07-24-2013, 02:07 PM #9
- Join Date
- Sep 2009
- Posts
- 4,738
- Location
- Murray, KY
- Tractor
- 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
That is a nice looking set of forks.
Like ETpilot we had problems with the short stuff falling between the two tines of our chain on forks so we bought the second set. Hope to test the set-up with four tines soon.
07-24-2013, 05:01 PM #10
- Join Date
- Jul 2013
- Posts
- 12
- Location
- Alabaster, AL
- Tractor
- Kubota BX25D
Finally got to thy them out today. They work absolutely awesome. I had a huge pile of brush including 3-4 20ft long trees and a pine stump that was 12" around and about 5 ft long. It picked up the hole pile in two trips! It is unbelievably strong! I even picked up a huge rock that was about 20" around and bounced it up and down on the tips of the times and it took it just fine! Anyway, I snapped a few shots for you guys to check out:
Similar Threads
Home made brush forks (tine strength)
By Chain Bender in forum Build-It YourselfReplies: 7Last Post: 05-01-2011, 01:42 PM -
Front-End Loader bucket forks/brush forks
By honthaas in forum AttachmentsReplies: 4Last Post: 10-11-2010, 08:07 PM -
My DIY forks / trailer mover / brush forks etc.
By TexSparx in forum Build-It YourselfReplies: 1Last Post: 06-14-2009, 09:42 PM -
FEL forks I made
By BobQ in forum Build-It YourselfReplies: 7Last Post: 08-05-2007, 11:35 AM -
3-pt forks made out of pallet truck
By RyanL in forum Build-It YourselfReplies: 6Last Post: 02-11-2004, 09:37 PM
