Results 1 to 8 of 8
  1. #1
    Silver Member nsmithnd's Avatar
    Join Date
    Feb 2011
    Posts
    102
    Bismarck, ND
    Ford 1700
    Default snow-blower chute rotation issues
    Curious if anyone might have ideas for a simple fix/modification for a binding 3 point snow blower chute.
    The two close-up shots are not of the actual unit, but are similar to what I've got (seen in the "fuzzy" pic).
    Instead of the 3 tabs holding the chute on, it has a split retaining ring which is installed below the lip on the snow blower end of things.
    Then the chute is set on and the 3 bolts are attached to hold it in place.
    The (sharp) bottom edge of the chute then rides on the lip (metal on metal).
    Was thinking if the chute could be raised just a hair, and a set of nylon wheels attached to ride on the lip, things would rotate much easier.
    Or would snow/ice build up and cause problems?
    Maybe a matching lip on the chute end with an anti-friction ring (if I could find one - 10-1/4" inside diameter x 12" outside diameter)?
    Also, the crank/cable mechanism is pretty bad.
    Considering switching over to a chain and sprocket setup.
    Or would snow/ice cause issues with chain as well?
    snow-blower chute rotation issues-snow-blower-chute-1-jpgsnow-blower chute rotation issues-snow-blower-chute-2-jpgsnow-blower chute rotation issues-snow-blower-chute-3-jpg
  2. #2
    Elite Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    2,678
    Vanderbilt, Michigan, USeh?
    Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST
    Default Re: snow-blower chute rotation issues
    Nothing wrong with rollers. But if you clean the metal up, put a good coat of paint on it, then smear on some white lithium grease... you should be good to go. Keeping it inside out of the weather would be a big plus, too. A normal chute that gets some yearly PM usually has fairly polished metal surfaces and is fairly easy to turn. Only time there may be be some binding is when blowing a heavy stream of snow and the chute 'rocks' back a little from the force of the snow. Other times, it is just kind of sitting there and you can turn it with your little finger.... My JRW has the same ring it sits on, and turns just fine... My chute is about 12" in diameter...
    78" [26"X10"fan] Mahindra front blower,72" Mahindra front blade, 48" CID QA forks, 6' EverythingAttachments Land Plane & Landscape Rake, 78" JRW rear blower[26"X8"fan], homemade 1 ton rear weight, 6' Ford rear blade, big homemade 3pt box/carrier, 8" wood chipper
  3. #3
    Join Date
    Feb 2011
    Posts
    102
    Bismarck, ND
    Ford 1700
    Thanks for the input, I cleaned the chute up with a flap disc and the paint is drying.
    Will get it greased up and mounted to check it out before looking at any modifications.
    Would definitely like to modify or eliminate the hand crank.
    Haven't had it on the tractor yet but looks like I might not be able to reach it from the seat.
    Your winch setup looks good, any issues with it? And is the roller spring loaded?
    -Neil
  4. #4
    Join Date
    Feb 2004
    Posts
    2,678
    I built a hand crank for when I used the blower on my JD 2240, but went electric when I got my new tractor... so I could use it on either [ no rear hyd on the 2240 ]. I have seen several guys use springs, but I just modified the cheapo winch I used by adding another hole/set screw for the other end of the cable. Here is a link to when I did it back in 2001... It works great, but just about any thing you fab up should work. There is almost no load on the winch. You could maybe modify the crank, too. It doesn't take much effort to spin the chute if you keep it cleaned up and lubed.... Good luck, Jerry...
    http://www.tractorbynet.com/forums/s...onversion.html
    2011, not 2001.... [ type faster than I think... or think slower than I type... ]
  5. #5
    Silver Member droptop's Avatar
    Join Date
    Jan 2012
    Posts
    218
    Western NY
    Massey Ferguson 1635 cab
    Grease is the best if you take it apart to apply, but I just pour some bar and chain oil down between the sections. The bar and chain oil has some additives to make it stick better than regular oil. The downside is it makes a mess.
  6. #6
    Veteran Member Lloyd_E's Avatar
    Join Date
    Nov 2003
    Posts
    1,498
    South Shore Nova Scotia Canada
    2008 Kioti DK 45 sc
    After the season use. I repaint all areas that need it including the worn insides of the shut. I oil and grease everything, tighten the cable etc. The only new thing I may try this year is to line the inside of the shut with plastic. Maybe an old kid's "crazy carpet" cut to size will work.
    Work hard to get it down - play like tomorrow may end!
    Small Horse Farm: 12.5 acres: 2008 Kioti Dk 45SC with Cab, FEL, BH, 6' snow blower, 7' back blade, 7' box blade, 6' bush hog, 9"& 14" auger, 8' chain harrow, 4" chipper, sand spreader, 7' landscape rake, 3pt quick attach & coffee holder.
  7. #7
    Join Date
    Feb 2011
    Posts
    102
    Bismarck, ND
    Ford 1700
    Got the chute and mating surface all cleaned up and painted and re-assembled with lithium grease (as recommended).
    Works great now !! Next step will be to get it mounted and see how easy it is to reach.
    Thanks for the suggestions.
    -Neil
  8. #8
    Super Member
    Join Date
    Aug 2004
    Posts
    6,482
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Quote Originally Posted by Lloyd_E View Post
    I have tried that and it does work, I did however have somewhat thicker plastic.
    You only need to fasten the plastic at the bottom end of the chute, like 3or 4 ea 3/16" short bolts.
    The sides are not as important as the back.
    Like U I spray paint all bare metal with a rattle can just to stop rust forming. Once winter sets in and the 'rattle an paint' gets worn off we are down to shiney steel that in cold weather wont rust.
    Deep rust is what causes the chute to clog as snow catches on pitted rusty metal.
Similar Threads
  1. Snow Equipment Owning/Operating Snow Blower with hydraulic rotation question.
    By smalltown in forum Snow Removal
    Last Post: 09-29-2013, 03:54 PM
  2. Snow blower chute hydro rotation
    By sandyc in forum Kubota Owning/Operating
    Last Post: 09-20-2013, 07:20 PM
  3. Replies: 4
    Last Post: 12-16-2012, 04:37 PM
  4. remotes for snow blower chute rotation
    By simonmeridew in forum Kubota Owning/Operating
    Last Post: 09-02-2012, 08:50 AM
  5. JRW snow blower chute rotation mod
    By WBWI in forum Customization
    Last Post: 11-29-2010, 08:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
