Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1
    Join Date
    Jun 2012
    Posts
    62
    Central, NY
    NH 2005 TC40DA
    Default 3pt carry all gravity box?
    Well folks here is my idea...... I burn coal for heat, I buy about 3/4 ton every couple of weeks, I have a homemade single axle dump trailer that i currently use, but its too low for the coal to flow in the basement window. SOOOOO I am thinking of making a box to go on the FEL or a box on the 3 pt hitch, either way it would have to be like a mini gravity wagon. That way I could pull up to the side of the house, raise to the height I need and ramp it through the basement window.
    Open for ideas or suggestions as to if this is feasible. I have a NH TC40 with a 16a loader. I wouldn't get more than 3/4 ton at a time even though the coal bin in the basement holds 2.5 tons, I like to keep it full. I know people put a lot on the carry all's with firewood, but I was thinking more of the quick attachment on the FEL. I buy coal 1/4 mile down the road from my house, too easy to get and gives me tractor seat time.
    Any input would be great!
  2. #2
    Join Date
    Jun 2010
    Posts
    149
    Dunkirk
    Mahindra 60HST 60HP Diesel Compact 4WD Hydrostatic with factory cab, A/C, radio
    Default Re: 3pt carry all gravity box?
    I have a TC40DA w/16A loader. It only gets about 1200 pounds up on a 4' pallet so keep your box as wide as possible and as close to the tractor front end.
    Or
    I am assuming you have a bucket for your loader? Mine is about 1/2 yard. Why not make a chute through the window and just dump the bucket into it? Then you wouldn't have to worry about your loader capacity
    Quote Originally Posted by lloyd430 View Post
  3. #3
    Join Date
    Jun 2012
    Posts
    62
    Central, NY
    NH 2005 TC40DA
    I thought about that too, making a 6' box/chute outside and pouring in, only thoughts would be 2 or 3 trips more seat time though any ideas on the 3pt end, I should be able to get the height when I raise up.
  4. #4
    Platinum Member cartod's Avatar
    Join Date
    Aug 2008
    Posts
    872
    Northern, West Virginia
    JD 3320,255
    I wish you luck, how much does 3/4 ton of coal cost?
  5. #5
    Elite Member
    Join Date
    Sep 2009
    Posts
    2,738
    Up State S.C.
    AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
    Your access to coal takes me back. Our coal yard shut down about 30 years ago. Now, I wouldn't know where to buy coal if I had to.
  6. #6
    Join Date
    Jun 2012
    Posts
    62
    Central, NY
    NH 2005 TC40DA
    Coal up here is $240 ton loose, 3 ton min if delivered, $280 ton bagged. Cheapest most even heat I've ever had, I would not give it up! My dealer just sold out, new owners OK for now, but there are a couple of place within 20 minutes that sell coal, so I'm not too worried about it.
  7. #7
    Join Date
    Jun 2010
    Posts
    149
    Dunkirk
    My TC40DA does have much more guts on the 3PH either. I don't see how you can haul it all on one load with the tractor you have. 3 trips still beats shovelin'
  8. #8
    Join Date
    Jun 2012
    Posts
    62
    Central, NY
    NH 2005 TC40DA
    I'm thinking like a small gravity box 4'wide 4' tall and 2' deep with a pitch at the bottom to a coal chute. that would get me around 30+ square feet, they figure 40 for a ton of coal, but its actually 36 square feet. So in theory I could hold 1 ton, but i know I won't load it that full, do I put it on the FEL or on the 3pt? I scan some sketches tomorrow if I get a chance.
  9. #9
    Join Date
    Jun 2010
    Posts
    149
    Dunkirk
    If you put it on 3PH, it would help to have a hydraulic top link, you already have a tilt for FEL.
    Just had another idea. If your dump trailer is too low to dump into basement window, how about making a ramp to back trailer onto? One less handliong of the coal?
  10. #10
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,442
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Show a picture of your trailer. That might help, the 3pt with a dump well be low when dumped.
Similar Threads
  1. 430 3pt carry all ?
    By jacl in forum John Deere Lawn & Garden
    Last Post: 09-07-2011, 11:16 AM
  2. Show me your 3pt carry-all
    By Haywire in forum Kubota Owning/Operating
    Last Post: 12-06-2010, 09:01 PM
  3. carry box
    By PHIL850 in forum Build-It Yourself
    Last Post: 12-03-2009, 06:06 PM
  4. Carry all box
    By nh1520 in forum Customization
    Last Post: 11-24-2003, 03:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
