jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,388
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
A minor custom touch.
I wanted a place for my 5/16" Logging Chains convenient to the rear of the tractor.
I moved the small, gray, plastic, Kubota tool box from the rear to the left fender. Simple bolt through mount on left fender.
Removed small aluminum angle the Kubota tool box was mounted on and substituted a two inch piece of angle iron running the width of the rear of the tractor, to act as a wider, more secure base. Another simple drill and bolt through mount but secure nuts with lock washers.
Mounted half a steel 40mm ammo can (9" X 14" X 3-1/2") on the two inch angle to store 8' + 12' lengths of 5/16" Logging Chains. Chains are secured by gravity.
To the right, mounted a small, tough plastic basket, in which I carry infrequently used 3/16" chain, used to pull up smaller saplings by the roots with FEL. On saplings, 5/16" chain will slip; 3/16" grips. Also keep a can of spray graphite lube in the basket, to lube implement draw pins.
