A backup camera for $50!!!!!!!!!!!
   / A backup camera for $50!!!!!!!!!!! #371
Just bought a LS xr3037 does not seem to be much clearence for tire chains. Will screw in studs work on hard packed snow or ice ? I have the r4 tires front and rear.
   / A backup camera for $50!!!!!!!!!!! #372
Maybe a Moderator or Admin can most this post to the LS section.
   / A backup camera for $50!!!!!!!!!!! #373
A few nights ago, I was working late doing an aeration job on some baseball fields. With the holidays coming up, I had them turn the lights on so that I could work late. I have 2 cameras mounted front and rear on my tractor. This first video was taken at night with the stadium lights on. I could see the picture on the screen pretty good, and it was useful for viewing the aerator on the back of the tractor. The next video I will post is taken the next day in full sun. It will show that the system is pretty useless in full sun, even inside my cab.
   / A backup camera for $50!!!!!!!!!!! #374
This second video was taken the next day in full sun. As you can see, I couldn't really see anything on the screen and the system is pretty much useless in full sun. Later in the day, it became overcast and cloudy, and I could see a little better.
   / A backup camera for $50!!!!!!!!!!! #375
Hi all
An engineering kind of question - I am in the process of installing front and rear cameras (link) in my Kioti FX751 cab tractor. For the monitor, there is an unused bracket with a nut attached already welded to the ROPS top left in the cab, and then a corner brace as shown in the image below. I am considering drilling a small (~4-6mm) hole in the corner brace to hold a home made bracket about where the blue outline is on the photo. The "rules" are that you should never do anything like welding or drilling a ROPS as you might weaken it. Would drilling a hole that size in the ~10mm thick brace be enough to matter?
Thanks, Mort
   / A backup camera for $50!!!!!!!!!!! #376
As long as you don't punch thru, with your drill, and pierce your windshield, you will be okay. Is there enough space to put something between the ROPS brace and windshield?
When you fill new hole with a bolt, your brace will be just as strong as before.
Sent from my iPad using TractorByNet
   / A backup camera for $50!!!!!!!!!!! #377
Chances are you are probably safe. However I wasn't willing to risk it when I mounted lights to my ROPS. I clamped rather than drilled. I'd rather not screw with my safety devices, especially when other options won't be much harder.
Could you clamp a bracket to it instead of drilling relatively easy?
   / A backup camera for $50!!!!!!!!!!! #378
I agree it is best not risk altering a safety device. In an ideal world it would probably be a non issue. Should it ever fail at that point with another operator even if it did not become a legal concern I would still feel bad if someone got hurt or worse.
   / A backup camera for $50!!!!!!!!!!! #379
An n52 magnet 1" diameter by 1/4" thick will hold it on no problem.
   / A backup camera for $50!!!!!!!!!!! #380
Finally able to start installing the power rear view mirror and radio, still have to run the camera wires. :)
Nice set-up countrybumpkin!! I know that I am replying to an old post but I was wondering if you could elaborate on how you mounted this to the rear view mirror bracket? Is it mounted to a ball so that it can be tilted? If so could you take a picture of the backside of the display?
2016 DODGE RAM 3500 FLATBED (A58214)
2016 DODGE RAM...
Gradall 53409-45 Telehandler, Turbo Diesel Engine, 45' Reach, Rear Steer, 60" Forks, 6,699 Hours (A59076)
Gradall 53409-45...
1R PLANTER (A52708)
1R PLANTER (A52708)
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2018 RAM 2500 (A58214)
TANK MANIFOLD (A55745)
