Cement Wheel Weights
   / Cement Wheel Weights #1
Leejohn
Elite Member
Doniphan, Mo.
Kubota L4240, B7800 & BX2660
Cement Wheel Weights Update
A while back a guy was trying to put some he made into his wheels, never did find out if he got them in. After seeing that post I though I would give it a shot. Here are some pictures and tomorrow night I well have some pictures of how I did it.
   / Cement Wheel Weights #2
Looks great, how much weight have you added?
   / Cement Wheel Weights #3
So can you take the cement out of the rim if you need to repair or change a tire?
Each wheel is right at 80lbs, had to take a little back out of a 80 lb mix. I have rebar in them and that is why I said right at. This is my B7800.
I got it made so it should come out if ever need to. The tire can be changed without taking it out, in most cases. The 2 holes with the paper in them are for lifting rings. I well paint them after the cement gets all set up. People say cement shrinks up after it's all set up, I guess I well find out.
   / Cement Wheel Weights #6
OP, are your tires filled or is the cement the only ballast? Do you have anything securing the cement to the wheel? I would think after a little bit that the cement would work loose and banging around inside the wheel a bit???
RedNeckRacin My tires are loaded as you can see by the new pictures how I hold them in. Don't know if they well work loose yet only time well tell.
   / Cement Wheel Weights #8
You better get those balanced too.:rolleyes::D
   / Cement Wheel Weights #9
Yep, cement, or conc., will shrink, and I am curious how you will keep them attached to the wheels?
   / Cement Wheel Weights #10
I think there is a piece of threaded rod going through the three holes and welded to the rebar. Still a lot of work for about 80 lbs.
John Deere Gator (A53317)
John Deere Gator...
Sterling AT (A56436)
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
2000 Freightliner Discovery 36T 36ft. Class A Motorhome (A56859)
2000 Freightliner...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
PALLET OF 12IRON GATES (A58216)
PALLET OF 12IRON...
