Land Pride Rear blade customized
   / Land Pride Rear blade customized #1
DDT
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
The last snow we had I broke my cheap KK blade. It broke a weld on the pivot point and twisted the frame. not worth the effort.
I bought a new heavyer blade and put my hyd cylinder on this one to. I had to used linkage to make it work this time around.
Re: Land Pride Rear blade customized
Pic did not go.
another veiw
one more
   / Land Pride Rear blade customized #5
I like the set up you have.
I noticed parts are painted black and parts are painted Landpride tan. Did you fabricate that linkage yourself? Do you have a "before" picture so we can see what it originally looked like?
I painted the linkage parts with a black spray paint and the LP paint was done with a brush. Black easyer and quicker to.
I made all the parts for the linkage and used 1" pins for pivot points. I all so had to lower the bottom pins 6" so my 4400 would lift it high enough. this blade is meant for a bigger tractor. No before pic's.
   / Land Pride Rear blade customized #7
When you have it in full swing how close does it come to touching your rear tire? Nice job on adding the hydraulics.
It will not hit the tire. Before I lowered the bottom pins I could swing it 360 degrees, it cleared 8" to 10"
   / Land Pride Rear blade customized #9
Dana, looks like you are talented in the metal working skills as well as the woodworking. Nice outfit. Adding top and tilt , would put you in the cat bird seat. I have a hilly driveway (gravel) to maintain...and try to keep it crowned in the middle, sloping off to an inside ditch. I have to manually adjust my drawbar to get the right angle that I need for controlling the water. I dream of the hydraulic links, and lift arms. Maybe someday.
sassafras
   / Land Pride Rear blade customized #10
I was wondering about tilt.
I have the materials and parts for making a dozer blade for my skid steer. It has two remotes, one wide open high flow and the other, foot operated low flow.
What has kept me from making the dozer attachment is I haven't figured out how to do tilt and twist with just one remote, the low flow one. /forums/images/graemlins/confused.gif
I agree with you on his installation. It does look like it's done right and well.
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2020 Freightliner M2 106 Elgin Eagle Series 4MF Street Sweeper Truck (A55852)
2020 Freightliner...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
2023 Club Car Carryall 700 Utility Cart (A55851)
2023 Club Car...
