Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Platinum Member jodebg's Avatar
    Join Date
    Mar 2012
    Posts
    574
    New Hartford, CT
    Kubota B7800
    Default Can these be extended?
    Came by a set of forks for sale.Can these be extended?-bolens-pallet-forks-jpgCan these be extended?-underarm-jpg
    My questions are can they be extended to 36-42"
    and will they be strong enough to use on the FEL
    and 3 ph with a max lift capacity of 1700 lbs.
    If so, any suggestions as to material to weld on to extend?
    My questions are regarding the forks. The brackets
    I will need to cut and reconfigure.
    These were used on a Bolens tractor. They fit onto a plow and
    were used to move materials.
    The forks are 3" wide and the upright bracket is 1/2" thick.
    John
  2. #2
    Join Date
    Dec 2014
    Posts
    771
    severna park
    New Holland 1925 Kubota bx 24
    Default Re: Can these be extended?
    It would be cheaper to buy a set
  3. #3
    Elite Member Industrial Toys's Avatar
    Join Date
    Feb 2008
    Posts
    2,982
    Ontario Canada
    Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
    Around here you can buy "condemmed" forks for a hundred bucks. Usually someone drilled a hole in them and that is a no-no. A hundred bucks doesn't go very far in material and labour to extend them.
  4. #4
    Veteran Member farm boy00's Avatar
    Join Date
    Jul 2014
    Posts
    1,020
    Sand lake mi.
    allis chalmers wd45 farm king 990 and a duzen others
    Default
    Quote Originally Posted by jodebg View Post
    Came by a set of forks for sale.<img src="http://www.tractorbynet.com/forums/files/customization/437699-can-these-extended-bolens-pallet-forks-jpg"/><img src="http://www.tractorbynet.com/forums/files/customization/437700-can-these-extended-underarm-jpg"/>
    Bolens??? I never knew they made bigger then garden tractors
    Men in denim built this country, men in suits destroyed it
  5. #5
    Join Date
    May 2015
    Posts
    642
    NE Wisconsin
    Kubota L3901
    Can they be extended? Yes. Will they handle 1700 lbs? Absolutely not! The half inch plate that those C channels are welded to will bend with that kind of leverage on them.
  6. #6
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,089
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    That looks like some kind of cast product. I wouldn't trust it to pick up 1700# as is. I have never seen forks made from anything other than solid hardened steel.
    Don't trust those things with any thing valuable till you load test them and don't let anyone or thing get underneath a load with those cast forks.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  7. #7
    Join Date
    Mar 2007
    Posts
    1,629
    Midwest
    Iseki TA 247. Husqvarna 54",Gravely Zero, Cub Zero,.Polaris 850 ATV's Stihl 018 026 Pro, 029, 034 Super AV, 039, 044 Mag. Stihl Pole Saw.
    If you do extend them. You may want to put heavier channel over the top of the whole fork and then beyond. Weld it in that way. I wouldn't do it end to end that's for sure.
  8. #8
    Join Date
    Mar 2012
    Posts
    574
    New Hartford, CT
    Kubota B7800
    Thanks for the information.
    I am not going to purchase these.
    Thanks again.
    John
  9. #9
    Join Date
    Feb 2014
    Posts
    1,340
    Metro/Brainerd, MN
    JD 5065e MFWD w/553 FEL
    Quote Originally Posted by Industrial Toys View Post
    I got lucky and found a pair that were just phased out in the middle of a yard full of nearly worthless junk that'd been bottom dragged well beyond the 10% limit for de-rating. Bottom paint was hardly scratched! $100 just the same.
  10. #10
    Elite Member 4570Man's Avatar
    Join Date
    Apr 2015
    Posts
    4,145
    Crossville, TN
    Kubota L3240, Kubota B7100, Kubota F2560, John Deer, F525 Mule 600
    Default
    Those forks look like cast iron. Their design looks to be poor all around. I would keep looking.
Similar Threads
  1. Extended warranty?
    By Firefighter Kubota in forum Kubota Owning/Operating
    Last Post: 09-14-2011, 03:12 AM
  2. Insurance Extended Warranty ????
    By RTJ49 in forum Kubota Owning/Operating
    Last Post: 05-13-2011, 09:25 PM
  3. Extended Oil Changes
    By regor66 in forum Oil, Fuel & Lubricants
    Last Post: 02-08-2005, 12:19 PM
  4. JD Extended warranty
    By Jim_n_Motown in forum John Deere Buying/Pricing
    Last Post: 01-16-2005, 11:34 PM
  5. NH extended warranty
    By rmorgan in forum New Holland Owning/Operating
    Last Post: 07-31-2001, 11:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
