Threepoint box blade to pull type conversion.
/ Threepoint box blade to pull type conversion. #1
countrybumpkin
Elite Member
Kioti, kubota
So after a few other projects got put in front of this one , I was finally able to start my box blade conversion, been trying to do this for a year or better. Any how, I have a threepoint box blade that I'm building a set of wheels and a tongue for it to convert it to a pull type. The tongue will pin into the lift arm pins and then a top link support will pin into the original top link hole and run down to the tongue for a brace. The wheels will have one side that can be adjusted with a extra cylinder to provide tilt for the box. Here is a pic of the wheel assembly I've got done so far.
/ Threepoint box blade to pull type conversion. #2
Pic didn't load..... Go figure.....
I would suggest one of two things on the tongue issue. Either put a cylinder where you described putting a top link brace. Or get a horizontal drawbar for your tractor 3pt arms and hitch the blade tongue to that. Reason being you are going to want vertical height adjustment and a method to control it very accurately. Just having the rear wheels adjustable with a cylinder will work, but not as smoothly as doing that adjustment with the tongue.
I've been wanting to do this for several years. Keep looking for a cheap used BB in the 7 or 8 foot range but haven't found one. Keep us posted on the progress.
Hint on the pictures, size has to be under 1MB or TBN will reject it.
Thanks Richard, I had planned on using a spare top link i had for a adjustable "brace" just to adjust for different draw bar heights but i just might go with your cylinder idea , it would allow for a better angle of cut adjustment on the fly. I have a couple of cylinders setting here not doing anything.
/ Threepoint box blade to pull type conversion. #4
Nice work on the rear wheel assembly!!!!
Are you going to control it with a cylinder for lift and a cylinder for tilt??
If so, we're gonna run out of rear remotes pretty quick!!! :)
Might want to stay with your rigid adjustable top link on the tongue and then use a drawbar on the 3pt.
I think you are going to want some pretty serious height ability on the BB. If not, it will high center when going over a hump that you don't want to cut.
Anxious to see your progress. Of course I'll steal all your good ideas!!!! :)
Yes hydraulic lift and tilt on the axle assembly , I have three remotes so I could do the hydraulic tongue. I have a couple of the draw bars for the lift arms so I could try that first and see how that works first. As for the lift height I should have about 12 " with the way Im setting up the cornet ion point for the cylinder, I also thought about using a cam setup to multiply the stroke length and allow me to mount the cylinder more flat, I'll know more about that when I get a little farther along. Oh use all the ideas you like, sort of what I've been doing along with adding my own from pics off the web and years of using large kilfer blades.
/ Threepoint box blade to pull type conversion. #6
Does the channel iron weld to the bb ? If so make it a bit longer , 6" for lift . You certainly can weld , looks good . You will love this when done . It will be so much easier to use . Keep posting on progress , Kevin .
/ Threepoint box blade to pull type conversion. #7
Nothing like a drawbar hitch on a bb . Eliminates all the agony and defeat of a 3 pt mount . Nice welds and fab . Keep us up to date . Kevin .
Thanks, yes the channel is going to be welded to the back for the pivot points. I think i understand what your getting at by extending the points farther back but doing that with the way i have it designed would actually reduce lift height , unless I'm thinking of a different t way then your saying.
/ Threepoint box blade to pull type conversion. #9
Can someone post a pic of something similar please? Im intrigued but don't think I really understand the goal. Pardon my ignorance.
Was able to get a little more work done on the conversion, have about 90% of the tongue finished. Have to install the bushings for the lift pins, a second brace on the hitch , and the top link brace mount. Made the hitch swivel 360 and tilt 180 so no binding on uneven ground.
A few more pics.
/ Threepoint box blade to pull type conversion. #13
Pivot hitch is nice as is all the fab. What are doing with this ? New house , new yard ? Like it ,now I am inspired . Show us the end results and vids ?
Thanks, I've got to finish the dirt work around my new shop building. Also help with my road maintenance. I haven't worked on it in a couple of days but should get back on it soon.
/ Threepoint box blade to pull type conversion. #15
There is probably a reason why you didn't go with a ball type hitch?
I had thought about one, but didn't want to have to keep putting a ball on and off the draw bar when switching implements.
A bit more progress on the conversion, about all i have left to finish os the tilt cylinder mounts, then clean up and paint.
/ Threepoint box blade to pull type conversion. #18
:thumbsup: Looking good.
/ Threepoint box blade to pull type conversion. #19
Very nice, I sent a couple of pictures to my brother who is a pretty good fabricator, he has an extra box scraper and junk metal pile if he ever catches up on his other projects.
/ Threepoint box blade to pull type conversion. #20
I think that was wise to add the piece of truck frame across the back of the BB. It's not designed to handle the loads the tires will now put on it.
Also like the top link setup. You can always add a cylinder there if you see the need. I really think if you hitch it to your 3pt you'll get along fine without one. Also, the farther apart the two "raise" points are the easier the blade will be to control. An inch of lift on your 3pt will raise the blade so little that it'll barely be noticeable. That's a good thing!!!! :)
2020 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
PENDING SELLER CONFIRMATIONS (A59905)
PENDING SELLER...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
2020 CATERPILLAR 302.7DCR EXCAVATOR (A60429)
2020 CATERPILLAR...
UNUSED IRANCH 22" MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 22"...
