supertaster
- Joined
- Mar 7, 2011
- Messages
- 98
- Location
- Nova Scotia
- Tractor
- Massey Ferguson 35 Diesel, Massey Ferguson 1736 cab Power Shuttle
The LED lights I installed interfere with the radio causing static. Has anyone had success with using ferrite core snap on assemblies?
The lights are currently connected using the factory wiring in the cab for the front and rear work lights.
Or, do you have other solutions?View attachment 457907
It is possible it will fix or attenuate the RFI from the lights. It is worth a try. I have used many ferrites on my Ethernet network in my house to attenuate the emissions from the CAT5E cables running from the network switch out to the workstations. The ARRL has many publications on suppressing RFI.
Radio Frequency Interference (RFI)
In a DC powerline situation such as yours , bypassing the lines with capacitors can also be a solution. you might try a .1 uF disk ceramic from positive to chassis. Make sure the voltage rating of the capacitor is 100 volts or higher. Try bypassing as close to the lights as possible. An inline inductor could also help. Or combinations of the above.
There is much to know about RFI, and this medium is too brief to go into it in detail
LEDs themselves shouldn't be causing any RFI at all. I'm sure their power supply that drops the voltage down to the 2.5v or whatever it LEDs want is the issue. Probably indicates cheap design or construction. Personally I'd look at replacing the lights with better quality ones rather than patching up cheap ones that might not last that long anyway.
Guess we won't have to worry about this when we get the chance to put some LEDs on our tractor - no radio
