TC18 Rear Remotes
   / TC18 Rear Remotes #1
Inspector507
Super Member
Central Ohio
Picked up my remote kit today for the TC18. Bud, who delivered my tractor last year, offered last week to help me install them when I was ready. Of course he was off work today and I was ready TODAY.
Here are all the parts as taken out of the box.
Seat was removed to make life simpler.
   / TC18 Rear Remotes
This is the new valve with the control lever attached. 2 roll pins are used to keep it on. NH suggests installing it before you install the valve. I think they were right on this one. It would have been very ackward to install the lever afterwards. I remeber reading here about removing the tire, but that was on a larger tractor. That wouldnt have helped at all on a TC18.
   / TC18 Rear Remotes
Old valve has been removed and gasket scraped off. Probably should have gotten rid of the grass while I was at it, but now I had an open hydraulic system and didnt want to get grass inside.
   / TC18 Rear Remotes
Old valve with original o-rings re-used, new valve, spacer and gasket ready to put back on. You get new o-rings for the new valve and spacer.
   / TC18 Rear Remotes
Valves now installed with longer bolts. This is actually a lot harder than it looks. Just not much room to work with in there.
   / TC18 Rear Remotes
Oil lines ready to install after female half of couplers installed.
   / TC18 Rear Remotes
Oil lines installed. Man what a hassle. You dont have enough room to get the eyebolts in from the back, from the front, from on top. I finally inlisted help from my wife and a 24" extension to get them in from below. Thats after I jacked the rear of the tractor up to be able to get the extension in there. Of course this is also after one of the o-rings fell out when I dropped an eyebolt. Looked for that thing for about 30 mins. There are certain places on a TC18 you just cant get your hands in.
   / TC18 Rear Remotes
Because of the new valve and spacer shifting the old valve out farther, they give you new control rods and arms in the kit. See why the seat needs removed?
   / TC18 Rear Remotes
Black tipped handle is the new control lever for the rear remotes. Self-centering valve.
   / TC18 Rear Remotes
Everthing installed along with the hydraulic top link I got from Jim McCuan at http://www.topandtilt.com
I may need to shorten the hoses some.
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2016 PETERBILT PB337 FLATBED TRUCK (A57192)
2016 PETERBILT...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
378467 (A51572)
378467 (A51572)
2023 John Deere 325G Track Loader (A53485)
2023 John Deere...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
