powerscol
After reading a lot of threads and looking at a lot of good jobs, I am wanting to replace the little plastic tool box on my Bobcat CT 235. I'm tired of things not fitting and getting wet and bouncing out and getting lost. I have a tight area behind the seat between the ROPS and back of seat. I also have a low speed warning placard and rear work light to fit around. I can remove my seat back manual holder to get more room, but its handy to have the manual available in the field - I also know exactly where it is.
Now the tough spot. The area a box/can can fit is 21 inches wide, 7 inches deep (toward seat) If I stay within this footprint, height should not be an issue. I have looked at every tool box HD carries and a few will fit, but I want to try and get the max size I can. A 40MM ammo can at 17x6.5x10.5 is perfect, but I have ZERO outlets around me.
Anyone know of a reliable online source. I dont want to spend and get a rusty dented POS. Does anyone know of a good tool box place that might have a better selection of skinny, long, tall units.
MY only other option I can see is to use some angle and span between the ROPS legs and mount the box higher. I would probably put an angle on both sides of the ROPS to give a wider mounting base.Then my choices of boxes opens up. I have one that will work. I am concerned with drilling the ROPS and having it still be strong. If I go this way, how big of bolts should I use. Last I would probably need some sort of tray for the tool box to sit on / mount to. Thoughts for sources on that, and should I use steel or aluminum angle. A C channel would also work if I can find one to cut and fit around the ROPS. I dont have a welder, so that option is out for now.
Thanks for any help with this
Keith
Keith
