Dadnatron
Quick question about setting up power from my tractor to my (soon to arrive) 12v GPI fuel transfer pump.
My intention is to use a new 2gu set of inexpensive jumper cables as cable. I was going to cut off the clamps and attach eyelets at one end, attaching it directly to the battery posts and run the cable along the frame, back towards the door, attaching it to the frame with strong Zipties. At this end, I was going to use Anderson type connectors, with ends on both the tractor as well as on the powercord from the pump. This 'should' also allow me to use this connection as a jumper cable source with Anderson --> clamp style cables.
The question I have is... is there anything I am missing?
Amazon.com: GPI 1161-11, M-15S-MU/FM2-G6N Aluminum Fuel Transfer Pump with Meter, 15 GPM, 12-VDC, .75-Inch Manual Unleaded Nozzle, 12-Foot X .75-Inch Dispensing Hose, 18-Foot Power Cord & Suction Pipe: Industrial & Scientific
These are my jumper cables... not the ones I intend to use for the battery cable
Amazon.com: Energizer 1-Gauge 8A Permanent installation kit Jumper Battery Cables with Quick Connect plug 3 Ft Booster Jump Start ENB-13 - 3' Allows you to boost a battery from behind a vehicle!: Automotive
connectors...
Amazon.com: Battery Quick Connect/Disconnect Wire Harness Plug Connector Recovery Winch Trailer 6-1 GAUGE: Automotive
connectors...
