mud roller
After having all the stuff for the better part of a year I finally got around to
installing an instrument cluster on the BX 25 hood.
I added a volt, Engine oil pressure and transmission Temperature gauge
to a pod located on the hood of the tractor.
All are electrically operated with the oil pressure and transmission temperature gauges having a remote sensor.
I am a fan of old fashion needle gauges with minimal brains.
The gauges supply voltage comes directly from the alternator through a 5 amp inline fuse, It
feeds all the gauges, when not running they will not kill the battery because I have earlier added a battery switch.
Not shown is a Plexiglas cover for wet operations.
With the mower on right now I have not yet installed the transmission temperature sensor,
it will get installed during the cold weather switch over.
I got the cluster pod on Amazon for 13$ and built the bracket out of left overs on hand.
Vibration has not been an issue,
At last I can see what's goin' on!!
My thanks to all the folks on tractorbynet for the great ideas!!
