Jasonwbryant
Right now when I haul my tractor, I wrap the axles with chain and use ratchet binders. This can be a hassle at times when I have to pull the tractor really far forward because of a long implement. I want to add some sort of tie down point to the frame just behind the front guard. The holes are already there so no frame modification is required. The largest hole looks to be about 5/8" diameter. I would love to be able to hook the ratchet binder directly to the tie down and skip using the chain on that end. Any ideas on where to find such item?
