Gitche Gumee Kid
Thinking of making a mount on my back blade for log retrieval.
GGK
GGK
Go with two in parallel if you can afford to.
Why would you need two 12k winches in parallel. You can easily double them with a pulley. If you doubled both you've got 48 thousand pounds of pull ( assuming the HF winch actually pulls its rated pull. And the battery size and charging capacity to make more than 1 pull would have to be massive.
I would assume he talking about dual batteries.
Brett
