npalen
Elite Member
Spent a few hours of my retirement making parts for these sway stabilizers for my Mahindra 3015 tractor which had the turnbuckle style.
The heim ball joints are purchased of course.
The tires on the Mahindra are very close to the 3PH so had to put a bend in the male telescoping member as shown.
Used 7/8" inch square C1018 for it and 1 1/4" x 3/16" square tubing for the female which leaves about 1/32" total sliding clearance. (The wall is actually about 0.170" on the tubing)
Had to bevel the corners on the 7/8" square to allow for the inside radii of the tubing and also machine a small groove to clear the weld flash inside the tubing.
The goal was to keep the design as compact as possible due to very limited space when the 3PH is spread wide for changing attachments.
Had the parts zinc plated to resist rust.
