TnT: Kubota's vs Integration Engineering, Part 1
   / TnT: Kubota's vs Integration Engineering, Part 1 #1
jmc
Elite Member
SW Indiana
Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
TnT: Kubota\'s vs Integration Engineering, Part 1
Bought a Kubota L4330 this summer from a relatively new dealer. Ordered it with Kubota's TnT option, dealer installed. Since the dealer had never seen one and I couldn't find a picture, I wasn't sure what to expect. What I was hoping for, at $700 plus tax, free freight, free installation, was a clean setup designed specifically for that tractor series. Attached is a picture.
The biggest surprise was how big these cylinders are. 3 3/8" diameter. One of these pictures has a quarter $ on the top link body end for scale. They must use this same option for the bigger M series. These are too big to fit the bottom attachment hole above the PTO.
The stiff, 3/8 hoses have a mind of their own and routing them neatly is impossible.
A cummulative effect of the large cylinders. nest of hoses, SMV sign, and ROPS in the down position makes it hard to see the ground near the rear of the tractor. You can't blame it all on the TnT but it contributes.
Also, these cylinders drift. I could see it the first morning I bush hogged. That is what prompted me to mention it to the dealer.
These components appear well made and they worked. There was no permanent Kubota ID on any of the parts unless it was stamped and painted over. I wonder if Kubota is just a middleman on a design they weren't too involved with. But at that price, they were a disappointment. When l mentioned those concerns to the dealer, HE VOLUNTEERED TO TAKE THEM BACK, FULL CREDIT.
Off to Integration Engineering, the subject of another post.
Re: TnT: Kubota\'s vs Integration Engineering, Part 1
Another Kubota TnT picture.
   / TnT: Kubota's vs Integration Engineering, Part 1 #3
The cylinders came from a third party source, probably Gannon. In my opinion at $700 the hoses and cylinders are way overpriced.
You could have sourced these components yourself for under $400. For example, the 3' hoses for the cylinders run about $15 each with fittings. A top link from CCM with check valves to prevent drifting will set you back $150. You will have to hobble together your own tilt cylinder and fork ends or use the Integration Engineering cylinder with check valves for $250.
I used 1/4" hoses for my cylinders. They are a little more flexible and restricted thus giving me more of a "feel" when working the cylinders.
Massey Ferguson 9250 (A56436)
Massey Ferguson...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
Sterling AT (A56436)
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
