Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 50
  1. #11
    Join Date
    Sep 2004
    Posts
    2,171
    Kansas, Butler county, Just east of DooDah
    Kubota L4200 GSTCA
    Default Re: Added Remote to FEL...
    kennyd … Very nice work… KennyV.
  2. #12
    Gold Member
    Join Date
    Jun 2004
    Posts
    348
    Nova Scotia, Canada
    JD 4210 E-Hydro
    Kennyd.....
    Good to see you back, I think you said that you weren't gonna be around much because you were building a house ??? Right/Wrong ?? Anyway, I always enjoyed & learned from your posts & glad to see that you're back in the groove. Again, as usual, I think it's a great idea & setup, thanks for the info. How are you operating & controlling this ?? or did I miss something. This will be left/right angle ??
  3. #13
    Super Member
    Join Date
    Oct 2003
    Posts
    7,344
    Northeast, Ohio
    TC-40D SS New Holland
    Kenny you did a great job of making that project look as though it was a part of the JD package. We have been looking around for a similar valve arrangement but after seeing yours I really don't think it can get much better. Thanks for the great ideas. Hope to find out how it works for you after you get her all wired up.
  4. #14
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,089
    Westminster, MD
    John Deere 4110
    Thanks GoodGuy, I did finish the house, been in it for about 3 months now. I sure learned alot being my own GC!
    As I said in a earlier post, the wiring/switch installation still needs to be done...
  5. #15
    Join Date
    Jul 2003
    Posts
    11,089
    Westminster, MD
    John Deere 4110
    Thanks Mike!
    A little green paint(or orange,or blue) can sure make things looks like they belong!
    I sure enjoy your projects also.
  6. #16
    Join Date
    Jul 2003
    Posts
    11,089
    Westminster, MD
    John Deere 4110
    As promised, a few of the wiring pics...
    Here is the 20 amp circiut breaker mounted to the right of the battery.
    Attached Images Attached Images
  7. #17
    Join Date
    Jul 2003
    Posts
    11,089
    Westminster, MD
    John Deere 4110
    Here is the 30 amp relay mounted on the right side, it is triggered by the ignition key "ON" position. This way all the aditional current from the valve solenoid is handled by the relay and 10 gauge wire feeding it from the battery. I will also hook up ROPS lights to this relay when I add them.
  8. #18
    Join Date
    Jul 2003
    Posts
    11,089
    Westminster, MD
    John Deere 4110
    Here is the switch on the dash to operate the new remote, It is a sealed switch that I got at TSC.
    If I get home while the sun is still out tomarrow [img]/forums/images/graemlins/confused.gif[/img] I will put the loader back on and post some final pictures.
  9. #19
    Elite Member
    Join Date
    Oct 2000
    Posts
    3,039
    Windham County, Conn
    Ford 2120 , New Holland TN75D, Hitachi UH083LC Excavator
    Kenny, Looks great. Very professional job. My front remote is factory stock on my TN and requires the use of the rear hydraulic controls- quite cumbersome. I will look at adding a setup like yours to my 2120 as right now I run the lines for my grapple all the way to the rear hydraulics.
    Andy
  10. #20
    Super Member
    Join Date
    Oct 2003
    Posts
    7,344
    Northeast, Ohio
    Kenny if that dash switch is nothing more than a SPST switch then I might suggest that you mount a momentary contact button switch on your joystick as well. That way you could use either switch and never take your hand off the joystick to work your grapple.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
