Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
  1. #21
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,124
    Westminster, MD
    John Deere 4110
    Default Re: Added Remote to FEL...
    Mike,
    I thought of that too...and will probably do that when/if I do the grapple project. Right now, it will just be used for the plow, so having it on the dash is OK.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Join Date
    Jul 2003
    Posts
    11,124
    Westminster, MD
    John Deere 4110
    Thanks Andy,
    I think this is the best way to run a grapple or plow and not tie up a rear remote.
    Please let me know if I can help in any way.
  4. #23
    MMM
    MMM is offline
    Join Date
    Nov 2003
    Posts
    800
    Winn Parish, LA
    Case 380B, Super C
    Not to be a naysayer, but what is the advantage of this setup over power beyond sleeve from loader valve to 3rd valve to operate blade angle? I don't know much on snowplowing so I could be missing something, but for grapple seems a lot of switching for the convenience of using one spool for 2 circuits.
  5. #24
    Join Date
    Jul 2003
    Posts
    11,124
    Westminster, MD
    John Deere 4110
    MMM,
    It was partly a cost decision, this setup cost me around $300.00. To add a new spool valve, I would have to buy the Power Beyond kit ($210.00), a spool valve($150.00), twice as much hose, fittings and quick connects($150.00+) plus more real estate on the tractor to locate the spool valve.
    I feel the advantage is that all the hardware and additional plumbing is on the loader itself, where it will be used rather than running lines from the rear to the front of the tractor.
    Alot of switching? For a grapple I would put a momentary switch right on the joystick to operate the grapple(or blade angle) as suggested in a previous post, with a 3rd spool you would have to remove your hand from the from the joystick to the extra spool lever then back to the joystick when using the grapple.
    That seems like much more effort than pushing a switch [img]/forums/images/graemlins/wink.gif[/img]
  6. #25
    Join Date
    Jul 2003
    Posts
    11,124
    Westminster, MD
    John Deere 4110
    Here is a view from behind the loader mast, there is still plenty of room to remove the loader
    Attached Images Attached Images
  7. #26
    Join Date
    Jul 2003
    Posts
    11,124
    Westminster, MD
    John Deere 4110
    A front view...
  8. #27
    Join Date
    Jul 2003
    Posts
    11,124
    Westminster, MD
    John Deere 4110
    And finally a view from the seat...
    Thanks to all again! [img]/forums/images/graemlins/grin.gif[/img]
  9. #28
    Elite Member GerardC's Avatar
    Join Date
    Mar 2004
    Posts
    2,606
    New York
    KIOTI CK20 GEAR.
    If I didn't know any better, I'd say that was dealer installed. Excellent, excellent job. Good luck with it. G
  10. #29
    Super Star Member jinman's Avatar
    Join Date
    Feb 2001
    Posts
    18,980
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Kenny, I've looked at all your pictures and assembly. I think you've done a very nice job and it's easy to see you have a well thought-out project. The only thing I've seen that I'm not sure of is the electrical connection to your diverter valve. Is it just two bullet connectors? Do you expect those to hold up in the long run? I tend to think of that type of connector as semi-permanent, but no more often than you will disconnect/reconnect they may be sufficient. You have put a lot of value into this project far and above the $300 you spent on the parts. Nice job. [img]/forums/images/graemlins/cool.gif[/img]
  11. #30
    Join Date
    Jul 2003
    Posts
    11,124
    Westminster, MD
    John Deere 4110
    Thanks JinMan,
    The electrical connection is a High quality polarized plug from an old peice of test equipment that we had at work, it is factory made with the coiled cord and solid brass pins. There is really not a good picture of it. I also do not like bullet connectors.
    The other crimp-on connectors are filled with dielectric grease before crimping(with a ratchet style crimper) and further sealed with heat shrink. I did the trailer wiring on my truck and it has lasyed 12 years so far!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
