Results 31 to 40 of 50
12-15-2004, 10:40 AM #31
- Join Date
- Sep 2004
- Posts
- 90
- Location
- Edwardsville--Illinois
- Tractor
- NH TC 33D / ford NNA
Re: Added Remote to FEL...
Kenny: Awesome Job! Very well laid out and thought out, hat's off to you Kenny, I'll be waiting for your Grapple set-up so hurry Please! [img]/forums/images/graemlins/grin.gif[/img]
12-15-2004 10:40 AM # ADS
12-15-2004, 09:56 PM #32Platinum Member
- Join Date
- Nov 2003
- Posts
- 800
- Location
- Winn Parish, LA
- Tractor
- Case 380B, Super C
Just my ignorance of your loader setup. My valves are mounted on loader mast and PB sleeve for most (Prince etc)loader valves are $30, a single spool w/relief about $60. Guess I missed the joystick part. Nice installation btw.
12-16-2004, 09:15 PM #33Gold Member
- Join Date
- Dec 2004
- Posts
- 373
- Location
- Davidsonville, Maryland
- Tractor
- John Deere 4400, '48 B and 318
Kenny:
When we going to start cut and welding some metal for that thing!!!!!
Wayne [img]/forums/images/graemlins/cool.gif[/img]
12-16-2004, 09:51 PM #34
- Join Date
- Aug 2003
- Posts
- 37
- Location
- North Louisiana
- Tractor
- kubota L3130
kenny:
very nice! hey, did you drill holes all the way through the loader frame to mount your valve or did you do some welding or something?
12-17-2004, 06:25 AM #35
SanMan,
The 3 mounting hole(5/16") are only drilled through one side on the mast. The bottom of the mast is open, so I just reached up inside to put the washers and nylock nuts on.
12-17-2004, 08:51 PM #36
- Join Date
- Aug 2003
- Posts
- 37
- Location
- North Louisiana
- Tractor
- kubota L3130
I'am about to get started on set of grapples for my L3130.The mast an arm setup is a little different than yours but I do have room on the inside of the arm.
Since mine is tubular I was wondering do you think its ok to drill through or maybe weld some bolts on and slip the valve onto them with nuts an washers.
12-18-2004, 06:47 AM #37
Sanman,
I am hesitant to answer that question without seeing the setup you have, any chance of posting pics of the loader mast?
I did not pre-plan the location of the diverter valve, I ordered it and then when I had it in hand, set out to find the best, most out-of-the way place to mount it. If you are sure you are going to do this, go ahead and order just the valve.
Good Luck
12-18-2004, 12:34 PM #38
- Join Date
- Aug 2003
- Posts
- 37
- Location
- North Louisiana
- Tractor
- kubota L3130
kenny:
the loader frame is raised alittle bit to get a better view.the top two hoses are bucket curl, and I was thinking about mounting the valve between the loader pin and metal connectors which is about 12or13".
L the loader valve hoses to diverter IN, loop short hoses from OUT to the metal line connectors and L lines from diverter ports to grapple cylinder QD's.
12-18-2004, 12:41 PM #39
- Join Date
- Aug 2003
- Posts
- 37
- Location
- North Louisiana
- Tractor
- kubota L3130
as you can see, there's not much room anywhere else.
12-18-2004, 09:28 PM #40
That is a very cool setup. All gizmo freak grease monkeys are drooling! I haven't played with or thought it through but does anyone think this same setup could be modified to run remote tools like a log splitter or hydraulic jackhammer?
