Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
  1. #1
    Join Date
    Dec 2002
    Posts
    1,535
    Blair, Ne.
    L3130
    Default Gage wheel project
    This is part of my weekend project after months of telling myself I need some gauge wheels!
    Well first thing is cut some box tube on the band saw, punch some holes on the drill press and glue it to the KK landscape rake.
    Attached Images Attached Images
  2. #2
    Join Date
    Dec 2002
    Posts
    1,535
    Blair, Ne.
    L3130
    Default Re: Gage wheel project
    The next thing was to make some arms to plug into the receivers on the rake.
    The first round of doing this didn't quite work out. The straight one is the first attempt. While it worked the rake would always be dragging a tad and that was at the highest point.
    So plan B went into effect and worked out perfect.
  3. #3
    Join Date
    Dec 2002
    Posts
    1,535
    Blair, Ne.
    L3130
    This was the first one and as you can see it was topped out.
  4. #4
    Join Date
    Dec 2002
    Posts
    1,535
    Blair, Ne.
    L3130
    Here is a pic of the box blade with the tube welded up, I will use the same gauge wheels with the box.
  5. #5
    Join Date
    Dec 2002
    Posts
    1,535
    Blair, Ne.
    L3130
    Here is a pic of the new gauge wheels on the box blade. Must have missed getting a pic on the rake.
  6. #6
    Join Date
    Dec 2002
    Posts
    1,535
    Blair, Ne.
    L3130
    One of the other mods that had to be done was extend the toplink point on the landscape rake. The rake was tilted down on the front at a considerable angle. This means the gauge wheels would have been pointing in the air with out the mod. A 4" piece of steel fixed that right up so it sits level when the HTL is out.
  7. #7
    Join Date
    Dec 2002
    Posts
    1,535
    Blair, Ne.
    L3130
    This is how it sits after the mod...nice and level.
  8. #8
    Join Date
    Dec 2002
    Posts
    1,535
    Blair, Ne.
    L3130
    Extending the toplink mount is also the first step toward making the rake compatable with the QH. As you can see from this pic there was now way you could get the QH hook in there the way KK built it.
    The next phase in this will be to cut down the rake an inch on each side so its narrower than the 26" QH mounts. It would have been easier to just buy another rake but I get more torch and welding time this way [img]/forums/images/graemlins/grin.gif[/img]
  9. #9
    Join Date
    Dec 2002
    Posts
    1,535
    Blair, Ne.
    L3130
    This is what I need to cut down so the rake is narrower.
    You can also see the stand leg that was added to hold the rake up instead of blocks of wood.
  10. #10
    Join Date
    Dec 2002
    Posts
    1,535
    Blair, Ne.
    L3130
    Everything still needs to get primed and painted yet but I still gave it a quick spin around the place and it worked great.
    Still need to add receivers to the rear blade as well. Might get to that tommorrow.
    The tires were from HF on sale at about $8 each. The forks were purchased from the kubota dealer for under $50 for the pair. The steel used is about $50. I spent $132 on steel but it was for this and other stuff.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
