Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2001
    Posts
    130
    Northern NH
    JD4700HST
    Default Homemade Light bar
    Here are a couple of pictures of my homemade light bar. Rubber mounted low beam hologen lights. Wired into existing harness with separate toggle switch for rear light. Still needs a little dressing up but functional.. Hasn't been cleared off by all of the low hanging branches either. [img]/w3tcompact/icons/smile.gif[/img]
    Rich S.
    Attached Images Attached Images
  2. #2
    Join Date
    Oct 2000
    Posts
    291
    s.e.okla.
    4200 hst
    Default Re: Homemade Light bar
    looks real good.Big fellas too,gerzillion candle power?I agree that mounting inside the ROPS is the only way ta go if ya got low tree limbs.
  3. #3
    Join Date
    Dec 2000
    Posts
    966
    Tescott, Kansas
    Kubota M6040/cab
    RichS
    Neat idea! I mounted my front one in the same place. The only problem I have is I need some wide flat iron to extend under the light forward so when I look to the side or rear I don't get blinded.
    DDT
  4. #4
    Join Date
    Apr 2001
    Posts
    130
    Northern NH
    JD4700HST
    I have the tall ROPS and the light shoots right over my head. I was worried about that as well {turning my head and getting blinded} but I angled them so the beam hits 10 feet or so in front of tractor. If I had the short ROPS, would probably need blinders on.
    I was having a real problem seeing with the FEL and OEM lights. If the bucket was out of the way of the lights, then it was in the way so I couldn't see. If it was out of the way so I could see it was in the way of the lights. Grrrrrrr.
    It was a pretty simple set-up, the lights are Wagner H4703 low beam headlights. 55watts, 12.8 volts. So are pretty bright but it doesn't look like a jet coming in for a landing.
    The cases are all rubber and have a lip on the lower side in front of the lamp that protrudes an inch or so. Maybe that is why I am not getting blinded?!?
    The angle iron is a left-over piece from the Garage door brackets. Tons of holes just have to pick one. Wires run through the ROPS so no need to have wire ties, tape, etc. Feed it through existing holes in back of ROPS and secured with rubber insert to avoid chaffing. {sp}
    This is probably the part which will irk some people. Drilled and tapped two 3/8 in holes in the bottom of the ROPS to hold the bracket.
    Rich S.
  5. #5
    Join Date
    Apr 2000
    Posts
    658
    Central Wisconsin
    1986 Ford 1910 with 770B (FORD) loader, 4 MFWD; 1986 Bolens G214,back hoe,loader,MFWD (Iseki) 21 hp)
    A solution for "blinding light" when turning around etc is to make a shroud or shade with that thin black foam that goes in the bottom of tool box drawers and attach it with a long worm-gear clamp to the light. It's thin and pliable and no big deal if you bump it.
    RCH
  6. #6
    Super Member JerryG's Avatar
    Join Date
    Apr 2000
    Posts
    7,235
    Northwest Arkansas
    MF 1440-4 PowerShuttle
    RichS,
    They look good. I did mine almost the same way. I used a piece of aluminum angle and put two lights forward and two backward. Itís amazing how much nicer it is to work in the evening and night when you can see. I also did the no no thing, but I drilled for number 10 self-tapping screws.
  7. #7
    Join Date
    Dec 2000
    Posts
    966
    Tescott, Kansas
    Kubota M6040/cab
    Rch
    Thanks, That's a good idea. I've been trying to figure out a way for thin sheet metal but thoght that could slice one of my limbs, would't want to get red all over my JD.
    ddt
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
