Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Silver Member 53gravely's Avatar
    Join Date
    Nov 2004
    Posts
    142
    NJ/VT
    Kubota 7610 HSD
    Default Re: Adapt 6ft snowplow to 3 pt hitch???
    Ergonomic improvement....grabbing the pin with a gloved hand was a little tough....call it what you will, but God bless bailing wire!
    Attached Images Attached Images
  2. #22
    Join Date
    Nov 2004
    Posts
    142
    NJ/VT
    Kubota 7610 HSD
    I thought a little 7610 would have trouble pushing a full load of snow...no problem pushing this load anen when I got back on and resumed pushing. Granted the tires are loaded but the turfs in 4 wd really grab well.
    I bought chains which I don't think I'll need excapt maybe for a really deep wet snow with some ice under it.
    I really like having the plow on the back and the FEL on the front. I'm glad I did not tie up the FEL by adapting the plow to the front. My driveway is only 70 yds long....If I had a 1/4 mile driveway I think looking over the shoulder that long would give me a pretty sore neck and back but for me this is great!
  3. #23
    Gold Member
    Join Date
    Jan 2005
    Posts
    267
    White Mtns, NH
    B3000HSDCC
    That, sir, is a classic of its kind! I got a kick out of that "cellulose fiber strut", also being a cheap Scot.
    Good work!
  4. #24
    Join Date
    Nov 2004
    Posts
    142
    NJ/VT
    Kubota 7610 HSD
    Actually I left out the expense of the case of Budweiser that I gave my buddy for his kindness.....being a good neighbor I helped him drink it, too.
  5. #25
    Join Date
    Jun 2003
    Posts
    1,649
    Northern, New York
    Kubota L3830 03: RTV 900
    Nice lookin job, won't be long before you will be adapting it to the front.
  6. #26
    Join Date
    May 2012
    Posts
    971
    Quote Originally Posted by 53gravely View Post
    I know this is a very old post. I'm considering similar choices with a snowbear snowplow. Have you continued with this setup? Or did you change your mind eventually?
    Thanks for any updates... or links to updates that exist already...
  7. #27
    Join Date
    Nov 2004
    Posts
    142
    NJ/VT
    Kubota 7610 HSD
    Nope....remains the same to this day. I replaced the wood with another block after the original rotted from storing outside. Very glad I didn't tie up the bucket.
    I have plowed a crusted-over 2 1/2' with snow coming over the moldboard and it has handled it with chains on all four wheels. That was extreme and with the plow angled fully it would fishtail the front wheels. The instant solution was to pick up a massive chunk of frozen-solid snow from the old banks in the bucket for additional downforce out front.
    I highly recommend this rig if your driveway isn't too long. Having the FEL available on the front is VERY useful all winter.
    I would imagine the deflection with the plow angled would be far more pronounced with the plow way out in front of the bucket and from a damage perspective, 3 point hitch parts are a heck of a lot cheaper that fixing bent FEL arms.
    7610, BHog, 3pt.hitch snowplow, (2) Scag hydro 52, 1953 Gravely, Cub 104, and a partridge in a pear tree...BLAM...no more partridge.
  8. #28
    Join Date
    May 2012
    Posts
    971
    Default
    That's great! I haven't made up my mind yet, whether bucket mount or 3pt, but you have renewed my interest in trying the rear approach. Thanks.
    "The only thing necessary for the triumph [of evil] is for good men to do nothing." Edmund Burke*
    “If you continue in My word, then you are truly disciples of Mine;and you will know the truth, and the truth will make you free.” Ancient of Days
  9. #29
    Member
    Join Date
    Nov 2012
    Posts
    40
    ND
    Case IH DX25E, Case 444, JD440I, JD510
    I presume this will be mounted on your Kubota 7610 HSD? If so, that tractor appears to have enough belly to ground clearance for a belly blade. It's a time consuming project, but if you are good at mechanics, welding and hydraulics, it is a good thing to have. The belly blade not only is good for finishing a snow removal job, but for blading roads and finish leveling of dirt.
    The downside to a belly blade is they are not quickly removable (or at least mine is not). And in certain situations they will hang up the tractor and help get it stuck.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
