Rear Remotes on a JD4110
   / Rear Remotes on a JD4110 #1
kennyd
Advertiser
Westminster, MD
John Deere 3720 CAB/TLB, JD455
I added 2 rear remotes on my John Deere 4110 CUT, I used the Power Beyond kit from JD to access the hydraulics for the new valve.
The valve I used is a Danfoss valve purchased from the SurplusCenter
The first pic shows the mount I made and welded to ROPS x-bar. Rear View
Front view of the mount...
Test fit of the valve, Front view.
Rear view...
Test fit with the QD's and handles mounted, Front view.
Rear view....
This is the PowerBeyond block ready to install.
RR Tire and DSCV access panel removed, and the DSCV is unbolted the remove existing block that is sandwiched between the DSCV and the transmission.
Rear view, hard so see in there, and even harder to work in the tight space.
It's all plumbed and finished, The vew valve fit perfectly in the small space between the ROPS and the seat.
