Another homemade toothbar
   / Another homemade toothbar #1
JohnF_ASI
Member
QLD, Australia
Kubota L1501DT
Here's my version of a relatively simple toothbar for my 1200mm (4 foot) bucket.
I started by getting the main support and side bars in place so I could measure the total thickness for the teeth..
That allowed me to start cutting the teeth from 25mm (1") solid bar.
I did this with only 2 cuts using a drop saw - 1 at 45 degrees and 1 at 22.5 degrees (which gives the 45 degree slope when they're turned around)..
Then into 'production mode'..
Oops! Clicking too fast before attaching pic..
Welded and painted..
Closer view..
Slipped a couple of lengths of 30mm x 2mm SHS onto the 2 outside teeth and gave it a test..
Front view.. Couldn't have done this before.
Now I plan to make a set of 4 square tubes to slip onto the inside teeth so it can also be used as brush forks..
2015 Komatsu PC 210 LC (A53317)
2015 Komatsu PC...
2021 Deere 544P (A53317)
2021 Deere 544P...
UNUSED FUTURE 29" PALLET FORKS W/ MAST (A57193)
UNUSED FUTURE 29"...
UNUSED FUTURE HYD AUGER (A57193)
UNUSED FUTURE HYD...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
2016 International WorkStar 7400 21ft Cylinder Pallet Flatbed Truck (A55852)
2016 International...
