drawbar lock
   / drawbar lock #11
Closeup shot.. took about an hour to make - taking my time /forums/images/graemlins/wink.gif
   / drawbar lock #12
   / drawbar lock #13
TSC sells cat 1 locks cor 15$ now.. but I had made 2 for my old fords before tsc was carrying them.. here's some pics:
Here's another I buzzed together in 5 minutes using a piece of bent rebar, 2 pieces if "I" beam, a large "D" bolt, and a large nut/bolt/washer.
Here's one I welded up out of 1/4" plate and a large washer.
CNH sells a 20$ "A" frame kit to turn your 11 hole drawbar into a trailer ball holder as well.. looks like this.
Here's the old ford/ferguson style:
Most of these still need a 'stay' bar to keep the 3pt lift under the centerline of the axle, for safety.
Soundguy
   / drawbar lock #14
Soundguy
   / drawbar lock #15
Soundguy,
I purchased the TSC draw bar lock and It will not fit my John Deere 2010 cat2 set up without modification so I plan on making one similar to the ones you posted. I do not use the 3pt draw bar much so am in no hurry to make the lock. Thanks for posting the photos.
Farwell
   / drawbar lock #16
Soundguy,
Farwell
   / drawbar lock #17
Soundguy, How do I get a hold of CNH , I like that A frame setup, with my hydraulic top link hooking up a wagon would be a breeze. I edit'd this post AAH CNH = Case New Holland I'm assuming, can I order the A frame from any dealer or do they have a web order service or ?
Steve
   / drawbar lock #18
Steve
   / drawbar lock #19
</font><font color="blue" class="small">( I purchased the TSC draw bar lock and It will not fit my John Deere 2010 cat2 set up )</font>
Yep.. i had to use the a-frame setup on my cat 2 tractors.
Soundguy
   / drawbar lock #20
Soundguy
2018 John Deere Z997R (A53317)
2018 John Deere...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
Mini Excavator (A55787)
Mini Excavator...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A57880)
2019 INTERNATIONAL...
