Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Oct 2006
    Posts
    20
    Sulphur, Louisiana
    Default Bucket Level Indicator
    I have an 852 loader on a kubota mx5000. Can someone tell me what and where to get a bucket level indicator? When I purchased my tractor, I asked about one and the salesman told me the one kubota has is really not worth the money. So now I see I really need something. Any suggestions?
    Thanks Wayne
  2. #2
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,802
    Nova Scotia, Canada
    Default Re: Bucket Level Indicator
    Practice is the best level indicator.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  3. #3
    Platinum Member bobodu's Avatar
    Join Date
    Mar 2004
    Posts
    954
    Whitley County,In.EIEIO
    Farmnought.Gravely Model L,Gravely Model LI,1941 Clinton two wheeler
    Bicycle flag......
    1945 Allis-Chalmers,1967 Wheelhorse.The wife has a bubble hooded Simplicity and a Dixon.
    Anything green here- has roots or gets spent!!!
  4. #4
    Join Date
    Sep 2005
    Posts
    731
    West Michigan
    B3030
    I got the idea for mine from a Woods loader and from comments here on TBN. It is very simple to make. You really don't even need the Heim joint swivel on the end. A 90* bend in the rod with a cotter key to hold it in place like Woods uses is just as good. On top it is just a simple eye bolt. I used tape to set the level position on flat ground. It is way better than the flat strap that is the stock level indicator on the kubota bucket.
    Attached Images Attached Images
  5. #5
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,113
    Peoria IL
    New holland TC(33)
    i have one on my FEL, but its fairly useless as its not marked in any kind of fashion.
    (i just need to get around to painting or marking some spots on it)
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  6. #6
    Join Date
    Jan 2002
    Posts
    837
    Tidewater VA.
    Ford '92 2120
    Tool, thats a great idea. My woods came with one but it attached to the curl cyl. and now that there in slop in the pins I'm always off by a hair. I like the idea of putting it on the bracket.
    Steve...
    "My biggest fear is that when I'm gone my wife will sell all my tractor gear for what I said I paid for it. "
  7. #7
    Elite Member milkman's Avatar
    Join Date
    Sep 2001
    Posts
    3,532
    Ky. Between Dead Horse Holler and Yellowbank
    BX2200, BCS 735
    Quote Originally Posted by Toolguy
    You really don't even need the Heim joint.
    I like the Heim Joint, they are way cool.
    Hate is like drinking poison, hoping your enemy will die. unknown author
  8. #8
    Super Member 3RRL's Avatar
    Join Date
    Oct 2005
    Posts
    6,825
    Foothills of the Giant Sequoia's, California
    55HP 4WD KAMA 554 and 4 x 4 Jinma 284
    Toolguy,
    I like the way you did yours especially using the eyebolt as a guide for the bar to slip through. It is so much more visible than mine. My indicator bar slides through tubing, and only the tip of it is exposed....I suppose that's good enough though? I did paint mine to indicate bucket position when the fel is ground level. However, like most things, once you get a "feel" for it you really don't need it. But I still use mine to give me an indication of where I'm at.
    Rob-
    ...The Older I get...the Better I Used to be...
    Member of the Month
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
