weldingisfun
- Joined
- Dec 12, 2006
- Messages
- 1,824
- Location
- West Bell County, Texas
- Tractor
- Mahindra 4500 4WD w/FEL, and Scotts S2048 lawn tractor
Beau said:Here are a couple of modifications that I made to my Jinma chipper:
First is a storage cart. It is a dumpster diving special. I could not have asked for a more perfect fit. I would consider this type of cart an absolute "must have" for anyone that owns this chipper. The chipper itself weighs about 800 lbs and is impossible to safely move when not on the 3 point hitch. When the chipper is on this storage cart it is effortless to move it in the garage on the concrete floor, and a simple matter to hook it up to the 3 point hitch lift arms. Highly recommended!
I completely agree wth Beau. You must have a dolly if you own one of these monsters. Since I was not as lucky as Beau to find one, in a dumpster, that looks like it was built for the job, I had to build one. Just finished it tonight and want you guys to take a look at it for some constructive criticism.
The T-bar is to prevent the chipper from tipping over. The feed chute tends to make it little unstable.
There is one more mod to be made to hold the PTO shaft. I marked it on picture 04. It will be a piece of 2x2 angle welded on, as shown, to form a cradle for the PTO shaft.
My wife moved this around inside the shop with little effort.
Picture 01: Shows the heavy duty swivel casters, steel wheels, 700 lb. capacity.
Picture 02: The dolly by itself showing the T-bar.
Picture 03: Chipper mounted.
Picture 04: Future mod to hold PTO shaft.
