Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Silver Member mars1952's Avatar
    Join Date
    Jan 2007
    Posts
    238
    Western North Carolina
    1999 John Deere 4300 12/12 sync-reverse
    Default Spud bar storage on FEL (Pry bar)
    Hi Everyone:
    I have been storing my spud bar on my FEL for about three years now. The cross member makes a convenient place to store it. I am on my second bungee cord the first one lasted about two years. At first I had a pry bar that was made in China stored there but it was slightly longer than the FEL bucket and I snagged it on a tree one day. I managed to straighten out the pry bar and shortly after that I found an old made in USA pry bar buried next to the corn crib. Who no how long it had been there. I knocked off about a pound of heavy rust and treated it with Rust Cure. It's just the right length and it was free so I'm not too worried about the rust.
    Marshall
    Attached Images Attached Images
    John Deere 4300, 420 loader, model 47 Backhoe and many other attachments.
    Ford F350 Super Duty 4X4 Crewcab
    Polaris Ranger XP 700
    Millermatic 251 MIG welder
    Miller Spectrum 625 Plasma cutter
    Upgrading John Deere Loader Cylinders
    John Deere 420 loader quick hitch rebuild
    Semi-Metallic Emergency Brake Pads for the Polaris Ranger
    Straightened, reinforced and added toothbar to FEL bucket
  2. #2
    Veteran Member BTDT's Avatar
    Join Date
    Sep 2006
    Posts
    2,209
    North Texas
    IH M Farmall-propane powered, H Farmall (father-in-laws), Ford 1300 diesel
    Default Re: Spud bar storage on FEL (Pry bar)
    Good idea for location to carry it , bad idea using bungee cord . I would hate to be traveling down the hiway and have that bar meet me coming down the road. Might want to secure with a pin and short piece of chain.
    Praise is not something you do to get closer to God, praise is a response to God being close to you.
  3. #3
    Join Date
    Jan 2007
    Posts
    238
    Hi BTDT:
    Are you suggesting that I drill a pin hole in the bar? That's easier said than done. I'd probably have to mount it up in the drill press. The bungees have held up well for three years and they cut down on the rattle. I only changed the last one because it was loosing its stretch.
    Marshall
    Quote Originally Posted by BTDT
  4. #4
    Join Date
    Sep 2006
    Posts
    2,209
    North Texas
    Quote Originally Posted by mars1952
    Hi BTDT:
    Marshall
    You could drill the bar, but I was thinking of welding a loop on top end or side near top. DPS Troopers down here make a good living writing tickets for what they consider "unsecured load".
  5. #5
    Join Date
    Jan 2007
    Posts
    238
    Around here in WNC the stuff has to fall off for you to get a ticket. Welding sounds alot easier than drilling.
    Marshall
  6. #6
    Platinum Member bigdad's Avatar
    Join Date
    Feb 2006
    Posts
    617
    West Central Illinois
    Kubota B7510
    That's a railroad lining bar. The square end is that shape to fit into a track jack. Dig around that corn crib some more and see if you can find a jack to go with the bar. They''re kind of handy too.
  7. #7
    Join Date
    Jan 2007
    Posts
    238
    Quote Originally Posted by bigdad
    Hi BigDad:
    That's an interesting idea. I was removing the top soil around the corn crib with a box scraper when I found the bar. I went down to the clay so I don't think there is anthing else to be found. Once I found the bar I did keep an eye out though. The bar looks just like a made in China pry bar that I recently purchase at Home Depot. One end is round, the other end is square with a bevel and middle is hex shaped. My tractor is out at my farm so I won't be able to take pictures until Monday but on Monday I will take a picture of the bar and post it.
    Marshall
  8. #8
    Join Date
    Jan 2007
    Posts
    238
    Hi BigDad: Sorry for the delay. Here is a full picture of the of the pry bar compared to a made in China bar.
    Marshall
    P.S. I still need pictures of a 430 loader (or equivalent) in the dump position.
  9. #9
    Platinum Member DMF's Avatar
    Join Date
    May 2005
    Posts
    648
    Mass
    Massey Ferguson 1552 Cab Model
    I made a rack on the back of my tractor for it. I use a heavy duty rubber bungee...
  10. #10
    Join Date
    Jan 2007
    Posts
    238
    Quote Originally Posted by DMF
    That look inconvenient. Probably doesn't rattle much either.
    Marshall
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
