Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Gold Member
    Join Date
    Jun 2006
    Posts
    330
    NW WA State
    1980 AC 5020
    Default Loader control valve, weird joystick pattern....
    I just received a joystick loader control valve I bought. Finally found some literature on it, now it seems to me that the joystick pattern is backwards.
    Here is the "standard" pattern:
    boom up
    bucket tip neutral bucket rollback
    boom down
    Here is the "optional" pattern", which seems standard to me:
    boom down
    bucket rollback neutral bucket tip
    boom up
    Part of it might be me, coming from using a vertical sticked joystick on a backhoe at work. This control valve will be mounted horizontally.
    Monte
  2. #2
    Elite Member
    Rest in Peace
    Join Date
    Apr 2003
    Posts
    3,741
    New Hampshire
    Kubota B2710, IH TD6-62 dozer with Drott 4n1 bucket loader
    Default Re: Loader control valve, weird joystick pattern....
    Since you don't tell us what brand valve you have, it is sort of difficult to help you.
    However, you can change the direction of a function's movement by simply swapping it's work port connections. What was Up will then become Down. You just have to be careful with things like float and regen detents.
    Some valves can actually change the direction by changing the linkage.
    Basically I would need more info in order to help further.
    My friends call me Mad, everyone else thinks I'm mad.
  3. #3
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Eh? Sure beats what i'm using!
    Soundguy
    Quote Originally Posted by montejw
    Monte
    Attached Images Attached Images
  4. #4
    Gold Member
    Join Date
    Jun 2006
    Posts
    330
    NW WA State
    1980 AC 5020
    Quote Originally Posted by MadReferee
    Oops. It's the Brand Hydraulics LV22RFSTKAB at Surplus Center.
    Surplus Center Item Detail
    Link to the "manual", pdf file about 2.2 mb.
    http://www.brand-hyd.com/lv/lv0207.pdf
    It's supposed to have regen for the bucket and float for the boom, so I'm not sure if I can just swap hoses.
    Monte
  5. #5
    Elite Member
    Rest in Peace
    Join Date
    Apr 2003
    Posts
    3,741
    New Hampshire
    Nothing weird about that valve, other than the way they drew the picture for the standard configuration. Just rotate the standard valve 180 degrees in either direction so the hose side is on the left as you look down at the handle and you have the standard pattern that is on most every CUT. That orientation might make it hard to mount hoses but that is the design of the valve.
    Awkard, maybe yes. Weird, absolutely not.
  6. #6
    Gold Member
    Join Date
    Jun 2006
    Posts
    330
    NW WA State
    1980 AC 5020
    Yeah, I see that now, good eye. Awkward for sure. The valve mounts high, above the cowling. It would have to be mounted "on edge" with the hoses pointed over the engine cowling. The stick is horizontal pointed toward the rear of the tractor.
    I spun the joystick anchor around 180. That gives me hoses up, valve flat, up stick is boom down. But left stick is bucket dump. If I make a new anchor plate and move the anchor to the opposite side it is now I'll have what I want.
    Weird that they put those drawings sort of upside down.
    Monte
  7. #7
    Gold Member
    Join Date
    Jun 2006
    Posts
    330
    NW WA State
    1980 AC 5020
    Quote Originally Posted by Soundguy
    Soundguy
    So..... what's that hooked to? Looks old.
    Monte
  8. #8
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    Monte
    That is the loader control valve ( tapped off tractor hyds on the hyd top cover - 4gpm! ) on my 1955 ford 850 with ford 711 1-arm loader. In the pics, that's the one with the blue loader. i also have a near identical 1955 ford 660 with a ford 722 1-arm loader with a similar valve setup.
    One spool is lift/drop, the other spool is dump/curl.
    Way better than using a wheel barrow.. even if the controlls are a little odd!
    Your joystick setup looks great to me.. etc.
    Soundguy
  9. #9
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,108
    Peoria IL
    New holland TC(33)
    i thought the bucket roll was weird on mine... but have come to like it
    bucketdown nutral bucketup --->quickdump
    so if you push right it ups then farther right past a detent quick dump, which I found great for flicking the joystick across the detent = wiggleing the bucket really well if your feathering material or have sticky material etc.
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  10. #10
    Join Date
    Jul 2003
    Posts
    92
    Southeast CT
    Kubota L5030 and KX161
    Sounguy that is the most unique loader i've ever seen...wow. I just love those old machines/designs.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
