BoonvilleKid
Member
- Joined
- Dec 15, 2010
- Messages
- 26
- Tractor
- Farmall Super C, Farmall Super C, Farmall Super C, John Deere 955, John Deere 955
Keep in mind that a lot of the old farm tractors used a positive-ground system.
Super C came out with either a Carter or a Zenith carb. I know Carter also made carbs for Chev. cars, like I had on my 50, 51 & 52 Chev.'s. I don't think they are in business now, as I believe Zenith now makes new carb's for Carter for replacement on old tractors. The parts dealer you went to apparently doesn't know too much about old tractors & doesn't have the books for reference. There were a LOT of different Zenith carb.'s made for the Super "C", so you must be careful to get the exact and correct replacement kit. Nine times out of 10 it's the float, if you have a problem. Sometimes even when the float is brand new out of the box. Put in another brand new one and it'll run fine. Go figure. :confused2:
