Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
  1. #11
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,133
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Farmall A spark problem
    Quote Originally Posted by norwaytractor View Post
    The points look fine.
    Not sure how to troubleshoot on this positive ground system, very confusing
    The swich only has one wire on it, so i guess the swich only conects the wire to ground when activating?
    When measuring between the "in" wire on the ignition housing and the ignition housing itself. Is there suppose to be conection all the time? Isn't the conection point supposed to be isolatet from the housing? I'm thinking I could have leakage to ground somewhere.
    positive ground only means the positive post of the battery is tied to chassis. otherwise.. the electrics work the same... forget the positive ground thing.
    as far as the points looking good thus they must be good?
    I wish I had that kind of super vision.
    use an ohm meter or test lamp to check them.. then jumper out the key switch and hot wire the coil.
    see what it gets you...
    with a test lamp inline, and running it over.. it should blink. if it stays on.. you have a short.. perhaps at condensor.. perhaps at feed thru insulator in side of dizzy.. if lamp never comes on. you are not making good contact.
  2. #12
    Join Date
    Jan 2009
    Posts
    1,523
    Rushville, Ohio
    Massey 180 Diesel
    Here is an exploded view of your Mag. You may want to pull the coil cap off, # 14 I believe, and check for moisture and corrosion under that cap.
    Also may want to check the condensor. I have a couple, apparently originals that have a brass shell. They get a green corrosion on them. Clean with some steel wool, or something similar, and they still work fine..!!
    Being under plastic for several years causes a lot of condensation in the worst places.
  3. #13
    Join Date
    Mar 2002
    Posts
    42,133
    Central florida
    just to b clear.. maggie or bat ignition?
  4. #14
    Join Date
    Jan 2009
    Posts
    1,523
    Rushville, Ohio
    Massey 180 Diesel
    Post #5
    H4 Magneto. Visually it lookes just fine, will take it apart to inspect now.
  5. #15
    New Member
    Join Date
    Oct 2012
    Posts
    13
    hareid
    Farmall
    Note sure how to post picture.
    The wire from coil has a full conection to ground all the time, even when points are open.
    Does this mean the coil is toast?
  6. #16
    New Member
    Join Date
    Oct 2012
    Posts
    13
    hareid
    Farmall
    I found that the conection screw that conects the coilwire,wire from ponts and condensator had a to big washer on the inside, so the washer was bearly sometimes touching the housing. After swapping to a smaller washer, the spark is now constant. I thought the spark was to small, but after comparing to my other farmall's, it is the same
    But it won't start. Took the carburator apart and cleaned it, but still its bearly popping.
    Checked the compression and found that i had 6 bars in 3 of the sylinders, but only 4 bars in one.
    What is the normal here?
    I'm thinking maybe the rings is stuck in one of the cylinders, will try to poor some oil into the cylinders and wait a few days.
  7. #17
    Join Date
    Mar 2002
    Posts
    42,133
    Central florida
    put in some atf and let it set..
  8. #18
    New Member
    Join Date
    Oct 2012
    Posts
    13
    hareid
    Farmall
    How do I find what kind of engine I have in my tractor?
    I think C-113, byt not sure.
    The tractor is a -46. Tryin' to find what kind of compression I am suppose to have.
  9. #19
    Join Date
    Mar 2002
    Posts
    42,133
    Central florida
    what do you have now? many engines in that size range spec 90-130 psi
  10. #20
    Silver Member Varmint1's Avatar
    Join Date
    Jun 2012
    Posts
    145
    Deville,La
    JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
    Default
    Look on the right hand side behind the mag/ dis and you'll see some casting numbers. Post the numbers and we can find out for you, most likely you have the 113 engine the 123 came out later and most of them had water pumps
Similar Threads
  1. farmall problem
    By wkblankenship in forum Parts/Repairs
    Last Post: 03-06-2012, 09:50 PM
  2. Replies: 3
    Last Post: 11-14-2011, 04:17 PM
  3. New Toy, No Spark. Problem Solved
    By Iplayfarmer in forum Parts/Repairs
    Last Post: 10-14-2011, 11:30 AM
  4. Farmall A governor problem
    By Dale0268 in forum Parts/Repairs
    Last Post: 04-26-2011, 06:42 PM
  5. Farmall Super C spark plugs
    By BoonvilleKid in forum Farmall Vintage Tractors
    Last Post: 02-18-2011, 09:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
