Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,721
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: C-123 Engine
    Quote Originally Posted by BobG_in_VA View Post
    I don't care what Rick did, I said that once you reach a certain level of torque/HP on these units you are in for other issues....That's all I'll say...and you can call it a sermon if you like..
    both you guys are having reading comprehension probs.
    I didn't say YOU were preaching a sermon. I said that rick wasn't preaching a sermon.
    oh well.. govt school probably... ;(
  2. #22
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,537
    Lincoln County, NC need new avatar!
    Just a Scag
    Rick...If you hang around C's, SC's, 200s, 230s, etc. long enough you will ultimately find out what the weak link in these units are...once you hit a certain horsepower/torque level you very well may find out the hard way....Oh yeah, "You get to figure the rest out on your own."....If you'd like to know you may ask politely....Not a sermon, just a thought. BobG in VA
    You shouldn't make assumptions about other's experiences. Kind of a moot point anyways, as I sold the tractor 10 years ago and the crankshaft is still in one piece.
    Spring is the season of optimism.
  3. #23
    Join Date
    Apr 2009
    Posts
    76
    Pointless adding hp to these tractors anyway. They already have more torque/hp than they can get to the ground without spinning out anyway. That said when I rebuilt my c123 I used thinner sleeves and domed pistons, it was the same price so I figured what they heck. before rebuild it spun out without stalling, after rebuild it spins out without stalling. Most noticeable effect is I can can get to the top of the big hill next to my parents farm in 4th now, never did that even when new :-)
  4. #24
    Join Date
    Mar 2002
    Posts
    52,721
    Central florida
    Quote Originally Posted by mad_planter View Post
    your observations about getting the hp tot he ground are not takin ginto account split loads. IE.. pto. With a few extra ponies available.. you can max out your drawbar AND still be putting out belt hp for other things.
  5. #25
    Bronze Member ghenges's Avatar
    Join Date
    Apr 2012
    Posts
    93
    Greensburg PA
    Farmall
    Quote Originally Posted by DJ54 View Post
    That's interesting about the C-135 cam..........
    Where did you find the lift/duration specs on the cams..?? Are they in the Blue Ribbon engine spec manual..?? I have a BR engine manual that covers several engines, but it's at the other farm.
    I'm guessing just a longer duration..?? I just happen to have a C-135 cam and gear, and a spare C-123 waiting on an engine stand to be OH'd for an A, as a play toy for plowing days.
    There are two camshafts for the C-135 engine.
    Engine serial number 100,500 & below went into model 330 & 340 tractors and had a cam lobe lift of .240 inches.(same specs as a C-123 cam)
    Engine serial number 100,500 & above went into model 404 tractors and had a cam lobe lift of .274 inches. Duration specs are the same as the C-123 engines..
    Serial 100,500 and above also had high dome firecrater OEM pistons and a 14 bolt bolt head. (see piston image below).
    C-123 Engine-c135-pistons-side-side-jpg
    C-123 Engine-375800r1-jpg
  6. #26
    Join Date
    Sep 2000
    Posts
    9,537
    Just a Scag
    [QUOTE=ghenges;3167982]There are two camshafts for the C-135 engine.
    353609R31 is the only C-135 cam available today. I don't recall which one I bought back in the day, but I'll wager it was the later one and the same one that is avaialble now.
  7. #27
    Join Date
    Apr 2012
    Posts
    93
    Greensburg PA
    Farmall
    Quote Originally Posted by RickB View Post
    Thanks,
    I submitted the information so that anyone considering purchasing a used C-135 camshaft would be aware that the higher lift camshaft came subsequent to serial number 100.500.
  8. #28
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,197
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Thanks..!! That's what confused me looking through the online Case/IH parts book, just showing the one cam used in many...
    The cam i have is out of a 135 used on a combine. A buddy of mine scrapped it out about 15 years ago. He passed away, and his Dad told me to come get the engine parts. Block was cracked, so it went for scrap.
  9. #29
    Join Date
    Sep 2000
    Posts
    9,537
    Just a Scag
    Quote Originally Posted by ghenges View Post
    Thanks,
    That info is useful.
Similar Threads
  1. which cub to buy 123 or 782?
    By flyweed in forum Cub Cadet Tractors
    Last Post: 02-29-2012, 02:19 PM
  2. Plow lift retrofit Cub 123
    By sandrade in forum Customization
    Last Post: 02-01-2011, 10:43 AM
  3. 1966 cub cadet 123 motor rebuild
    By over my head in forum Cub Cadet L&G
    Last Post: 02-22-2010, 08:47 PM
  4. Moving Implements with FEL as Easy as 123
    By jtn in forum Attachments
    Last Post: 02-15-2003, 09:26 AM
  5. Testing 123
    By MyCritterHaven in forum Kubota Buying/Pricing
    Last Post: 05-09-2002, 08:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
