Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    Jan 2013
    Posts
    7
    Greenville, SC
    New Holland TN60A, Farmall Super M
    Default 1953 Farmall Super M
    I am restoring a 53 super M and have a question about the belt pulley (not the gear box) on the right side of the tractor. I cleaned the pulley with Simple Green and got the gunk off and parts of the pulley face are clean and look dry, but the other parts seem to be impregnated with some type of dressing that I suppose protects the pulley face. Does anyone know what type of dressing is recommended? Thanks.
  2. #2
    Elite Member MIKE R's Avatar
    Join Date
    Sep 2010
    Posts
    3,500
    PRINCE TOWNSHIP, ONTARIO
    MASSEY 1020 and 1945 CASE SC, 1914 1 1/2 hp EMPIRE HIT AND MISS ENGINE
    Default Re: 1953 Farmall Super M
    I have heard of using shoe polish. The best is to get a belt with fresh dressing on it and get it loaded up. The heat will help get the dressing into the paper on the pulley. Yes the pulleys are paper not wood that they look like.
    "If the women don't find you handsome, they should at least find you handy" - Red Green
    PRINCE TOWNSHIP TRACTOR CRUISE WEBSITE
    https://sites.google.com/site/prince...torcruise/home
  3. #3
    New Member
    Join Date
    Jan 2013
    Posts
    7
    Greenville, SC
    Thanks. I actually smelled the pulley and the darker areas smell like burnt motor oil. You are probably right. It will take heat and pressure to load the pulley again.
  4. #4
    Join Date
    Jan 2009
    Posts
    1,523
    Rushville, Ohio
    Massey 180 Diesel
    What's on there is probably an old resin based dressing from the belt. For protecting the pulley, I guess a lot depends on if you plan on belting it up, whether for your own use, or at a show.
    Bee's wax, or a bit of Neatsfoot oil for leather should protect it. Although the neatsfoot may make it a bit slippery if your going to belt it up to something. Shouldn't take much...
  5. #5
    Join Date
    Jan 2009
    Posts
    1,523
    Rushville, Ohio
    Massey 180 Diesel
    I know there is still a partial stick out in the shop, from when we ran the hammermill years ago. I doubt the paper label on the outside is ledgable, but I'll look sometime.
  6. #6
    Join Date
    Jan 2009
    Posts
    1,523
    Rushville, Ohio
    Massey 180 Diesel
    It just dawned on me that I remember Dad pouring molasses on the belt one time, because the belt was slipping on the old F-14's steel pulley. Po' people have po' ways...
  7. #7
    Gold Member
    Join Date
    Sep 2009
    Posts
    432
    Up State S.C.
    AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
    I was pleased to see that someone, other than me called it 'burnt oil' instead of used oil or burned oil, then I saw your location and found that we're practically neighbors. Maybe it's a South Carolina term.
    Quote Originally Posted by wynnsong View Post
  8. #8
    New Member
    Join Date
    Jan 2013
    Posts
    7
    Greenville, SC
    Different question on the Super M...I have been told that the seat spring comes in 3 different stiffness's. One for light weight, one for medium and one for heavy weight guys. Any truth to this?
  9. #9
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,132
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    yep.. beeswax stick dressing was / is common
    Quote Originally Posted by DJ54 View Post
  10. #10
    Join Date
    Mar 2002
    Posts
    42,132
    Central florida
    i can recall, in leaner times, polishing a pair of black boots with a rag and a bit of cooking oil before going into work.
    i teel ya what. made em shine up and shed water as good as any 'shoe' polish conditioner did.. and was virtually free.
Similar Threads
  1. Michigan 1953 Farmall Cub
    By Matt_Meiser in forum Private Party Ads
    Last Post: 05-01-2012, 10:54 PM
  2. 1953 Farmall Bush hog belly mower stickers
    By ATM in forum Customization
    Last Post: 11-30-2011, 08:40 PM
  3. super m 1953 repairs- restore
    By Quicksilver in forum New Member Introductions
    Last Post: 03-08-2011, 05:01 PM
  4. 1953 Farmall Super M Brake Question
    By rblanken in forum Farmall Vintage Tractors
    Last Post: 06-18-2009, 12:21 PM
  5. 1953 Farmall Super C
    By Corm in forum Farmall Vintage Tractors
    Last Post: 05-20-2003, 07:01 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
