Results 1 to 8 of 8
02-24-2013, 12:41 AM #1New Member
- Join Date
- Feb 2013
- Posts
- 20
- Location
- Oklahoma
- Tractor
- 1945 Farmall A & 1965 Ford 5000
1945 Farmall A Hydraulics?
Is there anyway to install hydraulics on subject tractor other than the old exhaust lift?
02-24-2013, 05:59 AM #2
Mount a power steering pump on it, run it off the fan belt.
02-24-2013, 09:55 AM #3New Member
- Join Date
- Feb 2013
- Posts
- 2
- Location
- Poultney, Vermont
- Tractor
- Farmall Super A
Re: 1945 Farmall A Hydraulics?
My 2 cents: Farmall 55a has a good point, but in my experience your limited in flow and pressure ( umph or aka balls) if you need it. If your looking to add a loader to your A, I'm afraid you won't have enough "umph". If you look on some of the discount web sites like Northern Hydraulics, you can purchase a self contained hydraulic system for under $500.00 new. If you are thrifty, like me, I used an old snow plow hydraulic unit I had kicking around (electric over hydraulic) A bit more umph than the power steering unit I used on another tractor. Issue there would be if you still have the 6 volt positive ground electrical system on your Farmall A. In that case, mechanical (belt or PTO drive) would be better.
Hope that helps...
Rick
02-24-2013, 01:10 PM #4Elite Member
- Join Date
- Oct 2004
- Posts
- 4,920
- Location
- east wells,vt
- Tractor
- 1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Good Afternoon Jerry,
The power steering pump is probablly your best bet. They also make hyd pumps that fit on your PTO but of course every time you disengage your clutch your pump stops spining...
I have both A and Super A, there are plenty of Super A tractors out there looking for a home and a face lift ! :")scotty
,,,course,,it is gas,and gas is,,well,gas,,so,,but it kills the @#$$ oughta them yellow jackets,,,thingy
http://www.tractorbynet.com/content/...onth-scott_vt/
03-14-2013, 08:30 PM #5Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,074
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
transplant from another small letter series with hyds.
03-19-2013, 10:00 PM #6Silver Member
- Join Date
- May 2009
- Posts
- 128
- Location
- Central Illinois
- Tractor
- several kinds and sizes
Check the parts yards for a used factory SA complete hyd. system!---they wont be cheep, but it depends on how bad you want/need one!---one of my cubs has a HAND lift, so there is another option, there again depending on intended use of tractor! thanks; sonny580
03-19-2013, 11:28 PM #7New Member
- Join Date
- Feb 2013
- Posts
- 20
- Location
- Oklahoma
- Tractor
03-20-2013, 09:52 AM #8Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,074
- Location
- Central florida
- Tractor
keep us posted!
Similar Threads
Problems with 1945 Farmall A charging system
By Jerry Stevens in forum Farmall Vintage TractorsReplies: 20Last Post: 03-09-2013, 01:51 PM -
1945 Farmall A
By Jerry Stevens in forum Farmall Vintage TractorsReplies: 5Last Post: 03-01-2013, 11:54 PM -
1945 Farmall A
By Jerry Stevens in forum Case-IHReplies: 6Last Post: 02-22-2013, 10:29 AM -
Hydraulics on Farmall 656
By Bday in forum HydraulicsReplies: 20Last Post: 12-27-2012, 09:47 PM -
Farmall 460 Hydraulics
By Rford in forum Parts/RepairsReplies: 1Last Post: 08-21-2010, 09:45 AM
