Results 1 to 8 of 8
  1. #1
    Bronze Member TommyJD790's Avatar
    Join Date
    Dec 2009
    Posts
    82
    Connecticut
    John Deere 790, Farmall Super C
    Default Sickle Bar for Super C
    I'm looking to find a Sickle mower for my '52 Farmall Super C with 3 pt hitch.
    Most of the mowers I find say that you need 30hp min.
    Does anyone have a recommendation ?
    Tommy-
    John Deere 790, 300 FEL, Woods backhoe, Power Beyond Kit, Ramsplitter 16T logsplitter, Alamo 60" Flail Mower
    Farmall Super C
  2. #2
    Bronze Member ghenges's Avatar
    Join Date
    Apr 2012
    Posts
    93
    Greensburg PA
    Farmall
    Default Re: Sickle Bar for Super C
    Quote Originally Posted by TommyJD790 View Post
    Tommy-
    The ideal mower for your Super C with a three point hitch is the IH 1300 balanced head mower. And, you don't need hydraulics to lift the bar, the bar is mechanically raised as the 3 point lifts the mower.
    Sickle Bar for Super C-1712-jpg
    I know for certain this mower doesn't need 30 hp because I run a 1300 on my little 19hp JD750.
    The 19 hp is plenty of power, however, the JD 750 is a little light and when the bar clogs it pulls the front of the tractor sideways, rather convenient actually, I dubbed it the clog indicator.
    Clearing 100 acres I have cut some extremely rough stuff and on some moderately steep hills. The Farmall C or Super C would be an excellent platform for the 1300 mower, much more stability and traction than the little 750 with turf tires..
    Soon as the weather clears I am side mounting the same IH balanced head mower on an old $400 buck 1950 Farmall C. See image below for a side mount installation:
    The mower will be permanently mounted and that's all the tractor will be used for.
    Sickle Bar for Super C-sidemountmowerhardware-jpg
    "I know the end of humanity is near when my tractor comes with a place to store and plug in a cell phone, but no tool box" -- God's Country
  3. #3
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,137
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    I have run a couple different 7 footer's on my Super C's cutting hay with no problem. Although they are Fast Hitch mowers, 7', is 7'.
  4. #4
    Join Date
    Dec 2009
    Posts
    82
    Connecticut
    Thanks guys.
    The IH 1300 is exactly what I've been looking at. Good to know that the Super C can power it.
    I love that side mounted bar.
    Tommy-
    Farmall Super C
  5. #5
    Super Member scott_vt's Avatar
    Join Date
    Oct 2004
    Posts
    5,134
    east wells,vt
    1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
    Good Afternoon Tommy,
    I have the old rear mount 16A mower for my 42 A and would really like to have a side mount like he one pictured and mount it on my 49 Super A. The side mount is the way to go IMO...
    Good Luck with it !
    scotty
    ,,,course,,it is gas,and gas is,,well,gas,,so,,but it kills the @#$$ oughta them yellow jackets,,,thingy
    http://www.tractorbynet.com/content/...onth-scott_vt/
  6. #6
    Gold Member farmeratheart's Avatar
    Join Date
    Aug 2008
    Posts
    385
    MD & Adirondack Mtns
    JD2520, JD650
    My Dad had a 200 Farmall with the fast hitch. He mowed an awful lot of hay with a 7' sickle bar mower on that 2 point fast hitch! Have fun with that old iron!
    Frank
  7. #7
    New Member
    Join Date
    Apr 2013
    Posts
    1
    Central Square, NY
    Super A
    I have a rear mounted sickle bar mower that can mow dtches. I had it hooked up to my Super A but it would work on a 100 and probably on a C. I am sellit if you are interested.
  8. #8
    Join Date
    Sep 2002
    Posts
    1,612
    Mt. Ulla, NC
    Satoh S-470D, Mitubishi FD 1450D
    A friend is looking for a 110 side mount. I've done some looking and have pretty much decided that the 110 is to hard to find parts for. The search may have to include the 1300.
Similar Threads
  1. Mowing John Deere 350 Sickle Bar Lift Bar Adjustment
    By KansasNewbe in forum John Deere Owning/Operating
    Last Post: 08-20-2012, 02:00 PM
  2. Sickle Bar cutter bar on sickle-bar mower bent
    By Pusto in forum Attachments
    Last Post: 06-29-2012, 12:12 AM
  3. Sickle bar for DK-40?
    By Coyote machine in forum Kioti Owning/Operating
    Last Post: 06-04-2012, 09:03 AM
  4. Remove sickle from sickle bar
    By Dexterdowns in forum John Deere Owning/Operating
    Last Post: 07-20-2011, 01:57 PM
  5. Sickle bar
    By ole mcdonald in forum Yanmar
    Last Post: 07-16-2009, 10:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
