Results 31 to 40 of 70
04-26-2013, 08:02 PM #31
- Join Date
- May 2012
- Posts
- 177
- Location
- bfe
- Tractor
- in search of new iron
Re: Farmall M
anyone?
04-26-2013, 08:12 PM #32
- Join Date
- Feb 2012
- Posts
- 712
- Location
- Summit. Ms
- Tractor
- JD 4840, 450j, 310, komatsu D31px22, IH 1486, MF 135, MHF TO35
How much lower is your lowest leak below your add oil valve? 1 inch? 6 inches?
04-27-2013, 05:24 AM #33
- Join Date
- May 2012
- Posts
- 177
- Location
- bfe
- Tractor
Re: Farmall M
the lowest leak is at the pto shaft maybe a inch or 2 higher then the add oil plug
04-27-2013, 06:54 AM #34
- Join Date
- Feb 2012
- Posts
- 712
- Location
- Summit. Ms
- Tractor
Well then i believe i would save that project till winter since your not going to be pulling it hard. That just me tho.
04-27-2013, 10:29 AM #35
- Join Date
- May 2012
- Posts
- 177
- Location
- bfe
- Tractor
Re: Farmall M
just a couply parades and couple antique pulls
04-27-2013, 02:31 PM #36
- Join Date
- May 2012
- Posts
- 177
- Location
- bfe
- Tractor
Re: Farmall M
I was hopeing I could just wait because id like to put a overrunning coupler on the pto also
04-28-2013, 02:32 PM #37
- Join Date
- May 2012
- Posts
- 177
- Location
- bfe
- Tractor
Re: Farmall M
okkkkkkkkkkkkkkkkkkkk
05-06-2013, 08:24 PM #38
- Join Date
- May 2012
- Posts
- 177
- Location
- bfe
- Tractor
Re: Farmall M
the people who I bought the m off of said they bailed hay/straw with it you farmall m guys what size bailer should I be looking for. also looking for a mower for it I was thinking a pull behind finins mower as I don't have 3 point or hydraulics do they have those that run on pto that my m could do?
05-06-2013, 09:17 PM #39
- Join Date
- Jan 2009
- Posts
- 3,195
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
Re: Farmall M
If you have a leak out from around the PTO shaft, and not even running, I'm thinking it's way overfilled. Check plug is on the left side, up ahead of the clutch pedal, and should be just below the level of the PTO shaft. Seals are still available through Case/IH. From past experience, I find it best to use OEM seals. I've mashed several cross over part number seals, and learned my lesson.
I've posted a lube chart for your M, should come in handy.... Click on the image, and it will enlarge. Save the picture to a file, and print it off for quick reference.
05-08-2013, 05:45 PM #40
- Join Date
- May 2012
- Posts
- 177
- Location
- bfe
- Tractor
Re: Farmall M
can anyone lead me on a way how to turn the throttle down so it doesnlt idle so high
Similar Threads
Farmall M
By angel in ME in forum Parts/RepairsReplies: 6Last Post: 07-22-2011, 04:42 PM -
Anyone with a Farmall 60
By Thumper & Buttercup in forum Case-IHReplies: 0Last Post: 03-30-2009, 04:58 PM -
Farmall 40 or 45
By KSSS in forum Case-IHReplies: 2Last Post: 03-11-2009, 08:33 PM -
Old Farmall
By lonesome in forum Farmall Vintage TractorsReplies: 2Last Post: 09-15-2004, 01:26 PM -
Farmall
By Thomas in forum PhotosReplies: 0Last Post: 10-02-2002, 05:46 AM
