Results 1 to 9 of 9
  1. #1
    Bronze Member damammel's Avatar
    Join Date
    Jun 2011
    Posts
    98
    Sterling Ct
    Yanmar 1500D
    Default 48 Farmall H leaking coolant
    I recently purchased a 48 Farmall H. I ran it yesterday for 15 minutes when I noticed coolant leaking from the overflow tube. The temp gauge is not working but with a temp gun the back of the head only read 144 F. I'm trying to determine what to inspect/replace. Not sure if it has the right cap or a faulty thermostat. I have not found much online about this except for it happening when working the tractor hard in hot weather. Neither of which I was doing yesterday.
  2. #2
    Join Date
    Apr 2012
    Posts
    2,156
    Northern Ontario, Canada
    2012 Kioti CK27HST w/cab
    Default Re: 48 Farmall H leaking coolant
    I would flush the rad and block thoroughly, then fill with a 50/50 mixture of antifreeze and water and put on a new rad cap. IF you have the tools, pressure test the cap and cooling system.
    These guys have manuals, but they are not cheap
    Tractor Manuals - Service, Repair, Operator and Parts Manuals
  3. #3
    Bronze Member Kiwi Farmall's Avatar
    Join Date
    Mar 2011
    Posts
    54
    Mossburn ,New Zealand
    1941 Mccormick Deering Farmall A and 1947 Mccormick Deering W4
    How much coolant is going out the overflow? Is the coolant covering the tubes or full all the way to the top? If filled to the top they will leak some until they find their own level. I would check and if needed replace the radiator cap first .
  4. #4
    Join Date
    Jun 2011
    Posts
    98
    Sterling Ct
    Yanmar 1500D
    Default
    Thanks for the replies. I actually got my operators manual in last night so I spent some time reading through it. Found that the radiator should only be filled to 2 1/4 inches below the opening. I'm very happy there's no actual issue. I still plan on doing a flush of the system, a new thermostat and a new gauge. Can't wait to start using the tractor.
  5. #5
    Super Star Member Egon's Avatar
    Join Date
    Aug 2001
    Posts
    18,129
    Nova Scotia, Canada
    After adding the new gear and using the tractor think oatmeal if it still persists.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  6. #6
    Super Member deerseeker001's Avatar
    Join Date
    Jul 2011
    Posts
    7,835
    Central wisconsin
    International 2500a with Loader
    I had a nice H that developed a leak at the Base of the Radiator had to pull it more than once.took to radiator repair shop.
    ::welcome :::RON
    never stop learning.
  7. #7
    Join Date
    Jun 2011
    Posts
    98
    Sterling Ct
    Yanmar 1500D
    Default
    How did it go with the repair shop? Was it worth having it fixed?
  8. #8
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    49,281
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    If it does turn out to be a leak. please get it fixed correctly. save pepper and oatmeal for the breakfast table.
    those home brew fixes as well as other 'plug up' stop leak fixes CAN work.. the problem is many fold however.
    1, think about this. they work by clogging up and puffing up. Think about your cooling system.. is having portions of it clogged up really all that much of a good idea?
    2, If you flush your system, plan on your magic-mix-fix flushing out also and leaving you with a leak at some point, or needing to retreat and hope it works and doesn't clog up the system.
    3, you have no idea when or if it will fail.. murphy says it's gonna fial while you are mowing and don't notice a small steam stream or spray while working up some dust then all of a sudden the engine locks up tight and you have this really ool red boat anchor because you used a food item to fix soemthing that needed solder or gasket, or oring or hose. Murphy says it will fail when you need it the most and or ar not paying close enough attention to halt catastrophic damage... and I don't wanna see that happen to you or your machine.
    I don't put radiator hoses or solder in my breakfast cerial.. and I don't put breakfast cerial into my radiator.
    best of luck... hopefully it was just overfull!
    souNdguy
    sent from my NOKIA LUMIA
  9. #9
    Join Date
    Jul 2011
    Posts
    7,835
    Central wisconsin
    They repaired the leak.it all depends on condition of your core.take it in and have them check.
    Quote Originally Posted by damammel View Post
    ::welcome :::RON
Similar Threads
  1. Replies: 0
    Last Post: 03-01-2014, 09:01 AM
  2. IH 3500A problems with coolant leaking around injector
    By dodgeram945 in forum Construction Equipment
    Last Post: 01-05-2012, 01:31 AM
  3. 4320 Leaking Coolant
    By Zinno87 in forum John Deere Owning/Operating
    Last Post: 06-20-2007, 07:03 PM
  4. MF 135 year of manufacture is 1969 leaking coolant
    By dexter195 in forum Parts/Repairs
    Last Post: 09-19-2005, 08:39 PM
  5. Slightly leaking head gasket on Farmall 130
    By upgw in forum Farmall Vintage Tractors
    Last Post: 07-19-2004, 08:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
