Results 1 to 8 of 8
  1. #1
    Gold Member
    Join Date
    Oct 2001
    Posts
    335
    SE PA
    Kubota BX2200, 1957 Farmall 130
    Default 1957 Farmall 130
    Current picture.. she's not here yet, but hopefuly soon...
    Attached Images Attached Images
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Veteran Member GreenRules's Avatar
    Join Date
    Apr 2002
    Posts
    1,451
    Casco, Maine
    New Holland t5040 JD 4110, 110. 212, 325, GT 225, 214, 112
    Default Re: 1957 Farmall 130
    Nice little tractor. Except for the grill, it looks just like my brother's 140.
  4. #3
    Elite Member 5030's Avatar
    Join Date
    Feb 2003
    Posts
    4,866
    Michigan, S.E. Monroe County
    Kubota M9000 Hyd shuttle/Massey 1085
    That's amazing. I had a 1941 Farmall A and the front wheel castings are exactly the same as is the steering box. Yours is 16 years newer.
  5. #4
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,524
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Too add to your private mail.. My 46 2n was more of a weld / braze candidate.
    Every bolt I could get at on that tractor had the nut
    welded on..!?!?! And just about everywhere else was brazed
    Soundguy
  6. #5
    Join Date
    Feb 2003
    Posts
    4,866
    Soundguy:
    Bet you have a really good relationship with your local welding supply house. [img]/forums/images/graemlins/grin.gif[/img]
  7. #6
    Gold Member
    Join Date
    Oct 2001
    Posts
    335
    SE PA
    I think I was told that this same model ran basically unchanged up into the late 60's...
    A few new stickers and a shift knob and she'll be all ready for 'work'!
    - Patrick
  8. #7
    Super Member
    Join Date
    Apr 2000
    Posts
    7,608
    Shingle Springs California
    New Holland TC40D
    They ran till the late 70's before production halted.
  9. #8
    Join Date
    Mar 2002
    Posts
    42,524
    Central florida
    I'm only just now becoming 'satisfied' with my welding skills. Thru hours of practice.. i can finally weld halfway decently on my small buzzbox. I have made a few larger projects.. like a heavy middle ramp for my trailer out of 1/2 inch material at work on out big lincold 225a BB.. ( nice welder ).. couse I got to play with all the nice stuff then too.. like the plasma cutter ( neato! ).. and the wire welder.. 200ish amps... ( neato!) again. I've never wire welded but once.. and was very easy.. lots easier than stick.. though surface prep seemed to make a big difference on the wire welder. I will say one thing about the lincoln though.. when you turn it up.. it will really glue some metal together. On that rusty 1/2 inch flad stock I thought I might have penetration problems.. Uh.. not! I think If I would have had chamfering rods I could have severed easilly..
    Soundguy
    Unfortunately it was the previous owner that liked the sparks and fumes. Instead of replacing about 6 bucks worth of bulk bolts and nuts.. he would just weld the bolt or nut on.. even if it was half way rusted off.
    I used a nut splitter, chissle, angle dringer, etc to remove lotsa nuts and bolts.. had to drill some out...
    Of those repairs i wasn't too happy.
    However he did make a few good braze repairs on the tin that were so good I didn't notice till I took the paint down.. as well as a welded oil pan.. no biggie.. it doesn't leak, and he did that repair about 20 years ago.. etc.
    Soundguy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
