Results 1 to 6 of 6
  1. #1
    Join Date
    Aug 2005
    Posts
    68
    Default 1952 Farmall Super ****
    Are there rebuilt or after market new carburators available for the 1952 Farmall Super A tractors?
    Thanks,
    Kevin
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,657
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 1952 Farmall Super ****
    Kits for sure.. however you might try denny's carb shop..or for the heckof it.. call your local case dealer.. you'd be surprised about what they still list for those old tractors..
    soundguy
  3. #3
    Super Member
    Join Date
    Apr 2000
    Posts
    8,386
    Shingle Springs California
    New Holland TC40D
    I go to two sites consistently; here, and YT Mag Out of the whole internet, these two are the places to check out.
    YT Mag has a on-line store. They have kits, carbs, and lots of other parts for older tractors. They also have links to other suppliers.
    I found my local tractor shop gets stuff through Tisco; I got a carb kit and float for my '41 Farmall A that way.
    Soundguy was right on too; the spring in my governer broke. Case had the gasket and spring required to fix it.
  4. #4
    Join Date
    Jul 2003
    Posts
    1,912
    Central VA, USA
    Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
    Check EBAY under Agriculture and search for Farmall Super or Farmall C and you will find new Zenith carbs for the Supers. Be aware that you may get sticker shock, but they can be had. Personnally, if the carb is not too bad off, I'd try and rebuild. they are very simple and easy to work on... Good Luck and get another 50 years out of that Super A. BobG in Va
  5. #5
    Join Date
    Jul 2002
    Posts
    1,171
    North of the Fingerlakes - NY
    Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
    Try:
    www.valu-bilt.com
    They've got most everything for any old tractor and have a heckuva catalog. May not be the cheapest, but they've always worked for me.
    Bob
  6. #6
    Join Date
    Mar 2002
    Posts
    52,657
    Central florida
    Also try:
    tractorpart.com
    Soundguy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
