Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
  1. #11
    Administrator
    Join Date
    Jul 2010
    Posts
    2,223
    San Diego, California
    None
    Default Re: food plots
    Welcome to TBN
    I moved your thread to the Food Plots forum.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Platinum Member Ted Summey's Avatar
    Join Date
    Feb 2012
    Posts
    682
    Germanton, NC
    Kubota MX5100F IH McCormick Farmall 140, Massey Ferguson 135
    +1 on the soil test.
  4. #13
    Zig
    Zig is offline
    New Member
    Join Date
    Mar 2012
    Posts
    9
    Bennington, Kansas
    John Deere 3038e
    I did not have a disc or a tiller and last year sprayed and killed about 2 acres with round up knock off. I mowed it down low with a shredder blade. I then used my box blade and dropped the tines down as far as I could and tore heck out of it. I let is set a couple of weeks and went over it several times with the box blade/tines low. I drug heavy log chain behind the box blade in a u shape to help break up clods. I did not need to lime as the ph was good. I put about 300 pounds of 12-12-12 on it. I planted brassicas, clover and alfalfa and wow did I get a nice crop of turnips, clover and alfalfa! Deer sure liked it!
  5. #14
    Platinum Member lakngulf's Avatar
    Join Date
    Oct 2009
    Posts
    596
    Lake Martin Alabama
    Kioti CK30
    Quote Originally Posted by Zig View Post
    I resemble the above remark. I have tried almost every option. Settle a few years back on a chisel plow and disc. Works great, but recently I decided to bite the bullet and get a five foot King Kutter Tiller from Tractor Supply. Unbelievable what it does on one pass on old pasture land with thick fescue and/or bermuda. I am sold on it, but my soil is sandy loam old pasture, so not much problem with roots, stumps, big rocks.
    I have a few food plots back in the woods. There I use the disc only, as the tiller would not deal so well with solid roots from big oaks, hickory and pines.
    Kioti CK30, KL130 FEL with Markham Toothbar, Land Pride 6' Mower, Atlas 6' BB,KK Tiller, KK Bushhog, Chisel Plow, Howse 66" Disc, 7' Spike Tooth, Hollow 300 Seeder
  6. #15
    Silver Member Avondale's Avatar
    Join Date
    Sep 2008
    Posts
    247
    Apple Hill, Ont
    Kioti DK 35; IH 574, Ranger 700 XP, Arctic Cat 500 TRV, Arctic Cat 400 FIS, Kawasaki 250 Bayou, Yamaha 200 BW.
    I say "use whatever you got". I had one plot was mid-jungle, used my backhoe to widen a path in and dug up about 1/3 to 1/4 acre, de-stoned and then disced & chain harrowed. Works very well. Took awhile but when you do what you love, doesn't seem like so much work.
    "Life is tough. It's tougher when you are stupid". John Wayne
  7. #16
    Elite Member
    Join Date
    Apr 2006
    Posts
    4,802
    Wise county Texas
    Kioti DK 35 now
    Looks like the thread was posted by a "drive by"
    Dennis
    "If at first you don't succeed, skydiving is not for you."
  8. #17
    New Member
    Join Date
    Feb 2013
    Posts
    13
    Stephenville Texas 76401
    IH 404 gas... IH 1086 Duals... Case 830 LP... & MiMi's Jubilee 1953 Ford Gas . It correct red frame correct fender color But has a pink Hood with 2 Red Hearts that say MiMi JUBILEE ..
    I've live on my farm for about 45 years now. I've got one food plot in the back it's about 5 ac . I've farmed it with every piece of equipment I've got . Jubilee case 830 and even my IH 1086 and a big offset. Best crop I had back there was a summer plot . I put it in with my 830 I just plowed it with a finishing tandem So I did not plow to deep . But then I used my whirly Bird seeder ... I mixed it all together . I had some of that Lab Lab . Soybeans. Corn. Black Eyed Peas. Milo. and a 50lb bag of spring mix from Bass Pro or some place like that. It rained that year ..
    .. When I drove up to that patch deer stood up an ran out for 15 minutes each time . It stayed ahead of them all summer and was about 4 ft tall .. Wife & I picked a log of BlackEyed Peas out of it.
    .....This winter it's dry and you can just barely see the Oats I have planted there & no deer. This year I rigged up an old grain drill that I'd not used in about 10 years. I was showing the grand Kids what can be done. I spend about $150.00 a year on my food plot avg.
  9. #18
    Elite Member
    Join Date
    Apr 2000
    Posts
    3,432
    Grayson County, TX
    Kubota B2710
    My disk has not touched the tractor since I got the tiller a few years ago.
    Alan L., TX
    South of Bugtussle
    North of Mustang
    On the banks of Buck Creek
    We don't rent pigs.
  10. #19
    Join Date
    Jan 2011
    Posts
    525
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota B3300SU 33-hp / 1,900 pounds
    Where I am in North Florida it is important to roll in your plot seed. We have two month Spring and two month Fall dry periods and rolling improves germination if weather does not cooperate.
    For years I pulled a Brinley water-filled plastic lawn roller behind my Kubota B3300SU. Took off the lawn roller rubber grips and inserted one length of 3/4" all-thread in each end of handle, inserted all-thread in 3-Pt. "eyes" then secured with washer and nut on each side. Roller filled in space between tractor tires giving total roll width, with tires, of 58".
    Roller available from Home Depot/Lowes, yard sales etc. Meant to be pulled/push by "hand" so frame is not strong enough to withstand REVERSE on tractor. Forward works fine. I carried roller to the food plot in bucket, then nutted into "eyes".
    Recently purchased a 60" Cultipacker from Everything Attachments. I am not sure germination will improve but intend Cultipacker will cure persistant erosion sites by rolling crimp pattern across slopes after seeding.
    Tractor is a Kubota B3300SU / 33-hp / 1,900 pounds.
    Attached Thumbnails Attached Thumbnails food plots-img_0531.jpg   food plots-img_0526.jpg
  11. #20
    Bronze Member DB Pilot's Avatar
    Join Date
    Feb 2013
    Posts
    77
    SW, New York
    David Brown 780 Selectomatic, L3800 Kubota, BX2200 Kubota
    I plowed up one food bed and then ran the disc over it. The second food plot I just ran the disc over grass. It was clay soil and the disc took a lot of time. So I think roto til. Since I don't have one, I think next time I will use herbicide and then disc. Just my experience. BTW
Similar Threads
  1. Help - what to do with Old food plots
    By Bdavis in forum Projects
    Last Post: 12-18-2012, 10:47 PM
  2. Food plots in!
    By hrcarver in forum Rural Living
    Last Post: 05-16-2011, 08:50 PM
  3. food plots
    By Jksnvly in forum John Deere Owning/Operating
    Last Post: 06-09-2006, 09:51 AM
  4. food plots
    By streetrodder in forum Yanmar
    Last Post: 12-31-2003, 05:27 PM
  5. Food Plots
    By Fisherman305 in forum Attachments
    Last Post: 09-27-2003, 08:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
